thinkgeo.mapsuite.routing.routinglayer
Table of Contents
ThinkGeo.MapSuite.Routing.RoutingLayer
<!– Class –> This layer can show start coordinates, end coordinates, a collection of in-between stops and the resulting paths with specified styles.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer</a>
Public MethodRoutingLayer This is a constructor for the class.
Public MethodRoutingLayer PointShape, PointShape, IEnumerable<PointShape> This is a constructor for the class.
Public MethodRoutingLayer IEnumerable<LineShape>
Public MethodRoutingLayer PointShape, PointShape, IEnumerable<PointShape>, IEnumerable<LineShape>
Public PropertyAttribution String Layer
Public PropertyBlueTranslation Single Layer
Public PropertyDrawingExceptionMode DrawingExceptionMode Layer
Public PropertyDrawingTime TimeSpan Layer
Public PropertyEndPoint PointShape Gets and sets the end coordinates for routing.
Public PropertyEndPointStyle PointStyle Gets and sets the style of EndPoint.
Public PropertyGreenTranslation Single Layer
Public PropertyHasBoundingBox Boolean Layer
Public PropertyIsGrayscale Boolean Layer
Public PropertyIsNegative Boolean Layer
Public PropertyIsOpen Boolean Layer
Public PropertyIsVisible Boolean Layer
Public PropertyKeyColors Collection<GeoColor> Layer
Public PropertyName String Layer
Public PropertyRedTranslation Single Layer
Public PropertyRequestDrawingInterval TimeSpan Layer
Public PropertyRouteStyle LineStyle Gets and sets the style of Routes.
Public PropertyRoutes Collection<LineShape> Gets the result path information for routing.
Public PropertyShowStopOrder Boolean Gets and sets the value that represents whether to show the ordinal number of each of the StopPoints when drawing layer. The default value is true.
Public PropertyStartPoint PointShape Gets and sets the start coordinates for routing.
Public PropertyStartPointStyle PointStyle Gets and sets the style of StartPoint.
Public PropertyStopPointStyle PointStyle Gets and sets the style of StopPoints.
Public PropertyStopPoints Collection<PointShape> Gets a collection that holds the stop coordinates between StartPoint and EndPoint for routing.
Public PropertyStopTextStyle TextStyle
Public PropertyTransparency Single Layer
Public PropertyXOffsetInPixelOfStopOrder Single Gets or sets the x offset (in pixels) of the stop order.
Public PropertyYOffsetInPixelOfStopOrder Single Gets or sets the y offset (in pixels) of the stop order.
Protected PropertyIsOpenCore Boolean Layer
RoutingLayer()
Overloads
This is the default constructor. If you use this constructor, then you should set the Routes property manually.
Name Type Description
Go Back
RoutingLayer(PointShape, PointShape, IEnumerable<PointShape>)
Overloads
This constructor allows you to provide the points for display.
This constructor gets the points ready to use.
startPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter represents the startPoint that you want to use in this class.
endPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter represents the endPoint that you want to use in this class.
stopPoints IEnumerable<PointShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.PointShape} –> This parameter represents the stopPoints that you want to use in this class.
Go Back
RoutingLayer(IEnumerable<LineShape>)
routes IEnumerable<LineShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.LineShape} –>
Go Back
RoutingLayer(PointShape, PointShape, IEnumerable<PointShape>, IEnumerable<LineShape>)
Go Back
CloneDeep()
Return Type Description
Layer<!– ThinkGeo.MapSuite.Core.Layer –>
Close()
Void<!– System.Void –>
Draw(GeoCanvas, Collection<SimpleCandidate>)
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –>
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –>
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
LoadLayer(Stream)
<!– static –>
layerStream Stream<!– System.IO.Stream –>
LoadLayer(Uri)
<!– static –>
layerUri Uri<!– System.Uri –>
Open()
RequestDrawing(TimeSpan, RequestDrawingBufferTimeType)
bufferTime TimeSpan<!– System.TimeSpan –>
bufferTimeType RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –>
extentsToRefresh IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –>
RequestDrawing(RectangleShape, TimeSpan)
extentToRefresh RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
RequestDrawing(RectangleShape, TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan)
RequestDrawing()
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing(TimeSpan)
String<!– System.String –>
CloneDeepCore()
CloseCore()
DrawAttributionCore(GeoCanvas, String)
attribution String<!– System.String –>
DrawCore(GeoCanvas, Collection<SimpleCandidate>)
This method will draw the routing result based on the specified styles.
This abstract method is called from the concrete public method Draw. This method draws the representation of the layer based on the extent you provided.When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter is the canvas object or a GeoImage to draw on.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.SimpleCandidate} –> This parameter represents the labels used for collision detection and duplication checking.
DrawException(GeoCanvas, Exception)
e Exception<!– System.Exception –>
DrawExceptionCore(GeoCanvas, Exception)
GetBoundingBoxCore()
args DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingAttributionLayerEventArgs –>
e DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawingExceptionLayerEventArgs –>
e DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.Core.DrawingProgressChangedEventArgs –>
args DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnAttributionLayerEventArgs –>
e DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.Core.DrawnExceptionLayerEventArgs –>
eventArgs RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestedDrawingLayerEventArgs –>
eventArgs RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.Core.RequestingDrawingLayerEventArgs –>
OpenCore()
Attribution
Return Type
BlueTranslation
Return Type
Single<!– System.Single –>
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –>
DrawingTime
Return Type
EndPoint
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#EndPoint” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#EndPoint</a>
Return Type
<!– ThinkGeo.MapSuite.Routing.RoutingLayer –> Go Back
EndPointStyle
If this property is not set, the default style is a small red marker representing the route end point.
Return Type
PointStyle<!– ThinkGeo.MapSuite.Core.PointStyle –>
GreenTranslation
Return Type
HasBoundingBox
Return Type
IsGrayscale
Return Type
IsNegative
Return Type
IsOpen
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsOpen” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsOpen</a>
Return Type
IsVisible
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsVisible” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsVisible</a>
Return Type
KeyColors
Return Type
Collection<GeoColor><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.GeoColor} –>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Name” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Name</a>
Return Type
RedTranslation
Return Type
Return Type
RouteStyle
If this property is not set, the default style is a purple pen with semitransparent color.
Return Type
LineStyle<!– ThinkGeo.MapSuite.Core.LineStyle –>
Routes
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Routes” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Routes</a>
Return Type
Collection<LineShape><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.LineShape} –>
ShowStopOrder
If this property is set to false, the text representing the sequence number of each stop will not be shown. This is ensured in the Draw method.
Return Type
StartPoint
Return Type
StartPointStyle
If this property is not set, the default style is a small green marker representing the route start point.
Return Type
StopPointStyle
If this property is not set, the default style is a small yellow marker representing a stop.
Return Type
StopPoints
Return Type
Collection<PointShape><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.PointShape} –>
StopTextStyle
Return Type
TextStyle<!– ThinkGeo.MapSuite.Core.TextStyle –>
Transparency
Return Type
Return Type
Return Type
IsOpenCore
Return Type
DrawingAttribution
Event Arguments
Event Arguments
DrawingException
Event Arguments
Event Arguments
Event Arguments
Event Arguments
DrawnAttribution
Event Arguments
Event Arguments
DrawnException
Event Arguments
Event Arguments
RequestedDrawing
Event Arguments
Event Arguments
RequestingDrawing
Event Arguments
Event Arguments
thinkgeo.mapsuite.routing.routinglayer.1440040134.txt.gz · Last modified: 2015/09/18 03:06 (external edit)
