thinkgeo.mapsuite.routing.routesegment
ThinkGeo.MapSuite.Routing.RouteSegment
<!– Class –> This class repesents a routeSegment, which is a base element in routing.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment</a>
Public MethodRouteSegment This is the default constructor for the class.
Public MethodRouteSegment String, Int32, Single, PointShape, IEnumerable<String>, PointShape, IEnumerable<String> This is the constructor for the class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyDistance Single
Public PropertyDrivingDirection DrivingDirection Gets or sets a value representing the next driving direction of the routeSegment. For example, if you are driving on the current routeSegment and will turn right on the next routeSegment, the value will be Right.
Public PropertyEndPoint PointShape Gets or sets a value representing the ending vertex of the routeSegment.
Public PropertyEndPointAdjacentIds Collection<String> Gets a value representing the adjacent feature IDs of the end point.
Public PropertyFeatureId String Gets or sets a value representing the feature ID of the routeSegment. It is an identity of a single routeSegment, thus you cannot set the feature ID to two or more routeSegments.
Public PropertyRouteSegmentType Int32 Gets or sets a value representing the type of routeSegment. You can define a value that represents kind of routeSegment, for example: 0 represents a local routeSegment, 1 represents a major routeSegment, 2 represents a highway.
Public PropertyStartPoint PointShape Gets or sets a value representing the starting vertex of the routeSegment.
Public PropertyStartPointAdjacentIds Collection<String> Gets a value represents the adjacent feature ids of start point.
Public PropertyWeight Single Gets or sets a value representing the weight of the routeSegment. It can represent, for example, the routeSegment length.
RouteSegment()
Name Type Description
Go Back
RouteSegment(String, Int32, Single, PointShape, IEnumerable<String>, PointShape, IEnumerable<String>)
This constructor allows you to provide the information for the routeSegment.
featureId String<!– System.String –> This parameter is the feature ID of the routeSegment. It is an identity of a single routeSegment, thus you cannot set the feature ID to two or more routeSegments.
routeSegmentType Int32<!– System.Int32 –> This parameter specifies the type of routeSegment. You can define a value that represents kind of routeSegment, for example: 0 represents a local routeSegment, 1 represents a major routeSegment, 2 represents a highway.
weight Single<!– System.Single –> This parameter is the weight of the routeSegment. It can represent, for example, the routeSegment length.
startPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter is the starting vertex of the routeSegment.
startPointAdjacentIds IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> This parameter is the adjacent feature IDs of the start point.
endPoint PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> This parameter is the ending vertex of the routeSegment.
endPointAdjacentIds IEnumerable<String><!– System.Collections.Generic.IEnumerable{System.String} –> This parameter is the adjacent feature IDs of the end point.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Type<!– System.Type –>
Void<!– System.Void –>
Distance
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#Distance” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#Distance</a>
Return Type
<!– ThinkGeo.MapSuite.Routing.RouteSegment –> Go Back
DrivingDirection
Return Type
DrivingDirection<!– ThinkGeo.MapSuite.Routing.DrivingDirection –>
EndPoint
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#EndPoint” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#EndPoint</a>
Return Type
EndPointAdjacentIds
Return Type
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –>
FeatureId
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#FeatureId” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#FeatureId</a>
Return Type
RouteSegmentType
Return Type
StartPoint
Return Type
Return Type
Weight
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#Weight” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#Weight</a>
Return Type
thinkgeo.mapsuite.routing.routesegment.1440040134.txt.gz · Last modified: 2015/09/18 03:06 (external edit)
