<!– Class –> This class represents the parameters passed out through the FindingRoute event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs
FindingRouteRoutingAlgorithmEventArgs | This is the default constructor. | ||
FindingRouteRoutingAlgorithmEventArgs | RouteSegment | This is the constructor that passed the routeSegment. |
IsPathTermination | Boolean | Gets or sets the value that represents whether the current routeSegment is the terminus. The default value is false. | |
RouteSegment | RouteSegment | Gets or sets the value that represents the current routeSegment during route. |
| routeSegment | RouteSegment<!– ThinkGeo.MapSuite.Routing.RouteSegment –> | The routeSegment that you want pass out by event. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#MemberwiseClone.28.29</a>
If you set the value to true, it will make the current routeSegment the terminus, which will break the route and return the path that has been routed thus far.
<!– ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs –> Go Back
The default value is null if you call the default constructor.
