thinkgeo.mapsuite.portablecore.worldlabelingcandidate
ThinkGeo.MapSuite.Core.WorldLabelingCandidate
    • ThinkGeo.MapSuite.Core.LabelingCandidate
      • ThinkGeo.MapSuite.Core.WorldLabelingCandidate
WorldLabelingCandidate()
This is a default constructor for the class.
If you use this constructor, then you should set the applicable properties manually.
WorldLabelingCandidate(String)
  • originalText
    • Description:This parameter represents the text of the label before it is potentially modified.
WorldLabelingCandidate(String,PointShape)
  • originalText
  • centerPointInWorldCoordinates
    • Description:This parameter is the center of the polygon (in world coordinates) representing the area to be labeled.
CenterPointInWorldCoordinates
This property gets or sets the Center Point position in world Coordinate system.
OriginalText
ScreenArea
CenterPoint
LabelInformation
thinkgeo.mapsuite.portablecore.worldlabelingcandidate.1442823692.txt.gz · Last modified: 2015/09/21 08:21 by admin
