thinkgeo.mapsuite.portablecore.worldlabelingcandidate
ThinkGeo.MapSuite.Core.WorldLabelingCandidate
    • ThinkGeo.MapSuite.Core.LabelingCandidate
      • ThinkGeo.MapSuite.Core.WorldLabelingCandidate
WorldLabelingCandidate()
  • This is a default constructor for the class.
  • If you use this constructor, then you should set the applicable properties manually.
WorldLabelingCandidate(String)
  • None
  • originalText
    • Description:This parameter represents the text of the label before it is potentially modified.
WorldLabelingCandidate(String,PointShape)
  • None
  • originalText
  • centerPointInWorldCoordinates
    • Description:This parameter is the center of the polygon (in world coordinates) representing the area to be labeled.
CenterPointInWorldCoordinates
  • This property gets or sets the Center Point position in world Coordinate system.
OriginalText
ScreenArea
CenterPoint
LabelInformation
thinkgeo.mapsuite.portablecore.worldlabelingcandidate.txt · Last modified: 2017/03/16 21:59 (external edit)
