thinkgeo.mapsuite.portablecore.wmsrastersource
ThinkGeo.MapSuite.Core.WmsRasterSource
Represents an object that encapsulates a Web Map Service (WMS) source.
    • ThinkGeo.MapSuite.Core.RasterSource
      • ThinkGeo.MapSuite.Core.WmsRasterSource
WmsRasterSource()
  • This is the constructor for the class. If you use this constructor, then you need to set the required properties manually.
  • None
WmsRasterSource(Uri)
  • This is the constructor the for the class.
  • This constructor initializes a new WmsRasterSource and downloads and parses the service description. In an ASP.NET application, the service description is automatically cached for 24 hours when it is not specified.
  • uri
    • Type:Uri
    • Description:URI of the WMS server.
WmsRasterSource(Uri,GeoWebProxy)
  • This constructor initializes a new WmsRasterSource and downloads and parses the service description In an ASP.NET application, the service description is automatically cached for 24 hours when it is not specified.
  • uri
    • Type:Uri
  • proxy
    • Description:Proxy to use for the current WMS layer.
GetFeatureInfo(ScreenPointF)
GetFeatureInfo(ScreenPointF,String)
  • infoFormat
GetFeatureInfo(ScreenPointF,Int32)
  • maxFeatures
GetFeatureInfo(ScreenPointF,String,Int32)
  • infoFormat
  • maxFeatures
GetServerLayerNames()
  • This method returns the names of all layers at the server side.
  • None.
  • Type:Collection<String>
  • Description:The names of all layers at the server side.
GetServerStyleNames()
  • This method returns the names of all styles at the server side.
  • None.
  • Description:The names of all styles at the server side.
GetServerOutputFormats()
  • This method returns the output format at the server side.
  • None.
  • Description:The output format at the server side.
GetServerCrss()
  • This method returns the projected or geographic coordinate reference systems to be used.
GetServerExceptionFormats()
  • This method returns the exception format at the server side.
  • None.
  • Description:The exception format at the server side.
GetServiceVersion()
  • This API gets the WMS server version of the service.
  • Description:Returns a string reflecting the version of the service in WMS.
GetServerFeatureInfoFormats()
  • This API gets the WMS server FeatureInfo formats of the service.
  • Description:This API returns the FeatureInfo formats supported on the server-side.
GetServerCapabilitiesXml()
  • This API gets the GetCapabilites document of the service.
  • Description:This API returns the GetCapabilites document of the service.
GetRequestUrl(RectangleShape,Int32,Int32)
  • Get the request URL from the client to the WMS.
  • Description:The request URL from the client to the WMS.
  • worldExtent
    • Description:The world extent requested by the client to get the map.
  • canvasWidth
    • Description:The returning map width, as well as the drawing canvas width.
  • canvasHeight
    • Description:The returning map height, as well as the drawing canvas height.
CloneDeep()
GetWorldFileText()
GetImageWidth()
GetImageHeight()
GetHorizontalResolution()
  • Type:Single
GetVerticalResolution()
  • Type:Single
GetBoundingBox()
GetProjectionText()
Open()
Close()
GetImage(RectangleShape,Int32,Int32)
  • canvasWidth
  • canvasHeight
BuildWmsGetFeatureInfoUri(ScreenPointF,String,Int32)
  • Type:Uri
  • infoFormat
  • maxFeatures
GetFeatureInfoCore(ScreenPointF,String,Int32)
  • infoFormat
  • maxFeatures
HandleResponse(WebRequest)
  • reqeust
    • Type:WebRequest
HandleResponseCore(WebRequest)
  • request
    • Type:WebRequest
HandleXmlInfoFormatResponse(XDocument)
  • xmlDocument
    • Type:XDocument
HandleXmlInfoFormatResponseCore(XDocument)
  • xmlDocument
    • Type:XDocument
SendWebRequest(WebRequest)
  • Type:WebResponse
  • webRequest
    • Type:WebRequest
SendWebRequestCore(WebRequest)
  • Type:WebResponse
  • webRequest
    • Type:WebRequest
OnSendingWebRequest(SendingWebRequestEventArgs)
OnSentWebRequest(SentWebRequestEventArgs)
GetRequestUrlCore(RectangleShape,Int32,Int32)
  • canvasWidth
  • canvasHeight
GetImageWidthCore()
  • This method returns the width of the image in screen coordinates.
  • This virtual method is called from the concrete method GetImageWidth. It returns the width of the image in screen coordinates.
  • Description:The width of the image in screen coordinates.
GetImageHeightCore()
  • This method returns the height of the image in screen coordinates.
  • This virtual method is called from the concrete method GetImageHeight. It returns the height of the image in screen coordinates.
  • Description:The height of the image in screen coordinates.
OpenCore()
  • This method opens the RasterSource so that it is initialized and ready to use.
  • This protected virtual method is called from the concrete public method Open. The Open method plays an important role, as it is responsible for initializing the RasterSource. Most methods on the RasterSource will throw an exception if the state of the RasterSource is not opened. When the map draws each layer, it will open the RasterSource as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the RasterSource. When implementing this abstract method, consider opening files for file-based sources, connecting to databases in the database-based sources and so on. You will get a chance to close these in the Close method of the RasterSource.
  • Description:None
CloseCore()
GetBoundingBoxCore()
  • This method returns the bounding box of the RasterSource.
  • Description:The bounding box of the RasterSource.
GetImageCore(RectangleShape,Int32,Int32)
  • This method returns an image based on the worldExtent and image width and height.
  • This method is responsible for returning the image based on the parameters passed in. As the core version of this method is abstract, you will need to override it when creating our own RasterSource.
  • Type:GeoImage
  • Description:This method returns an image based on the worldExtent and image width and height.
  • worldExtent
    • Description:This parameter represents the worldExtent you want to draw.
  • canvasWidth
    • Description:This parameter represents the width of the image you want to draw.
  • canvasHeight
    • Description:This parameter represents the height of the image you want to draw.
OnOpeningRasterSource(OpeningRasterSourceEventArgs)
OnOpenedRasterSource(OpenedRasterSourceEventArgs)
OnClosingRasterSource(ClosingRasterSourceEventArgs)
OnClosedRasterSource(ClosedRasterSourceEventArgs)
CloneDeepCore()
GetProjectionTextCore()
ActiveLayerNames
  • This property allows the active layers requested from the client to be shown on the map.
  • When requesting a map, a client may specify the layers to be shown on the map.
ActiveStyleNames
  • This property allows the active styles requested from the client to be shown on the map.
  • When requesting a map, a client may specify the styles to be shown on the map.
Uri
  • This property specifies the URI of the WMS server.
  • Type:Uri
IsTransparent
  • This property gets or sets whether the response map image's background color is transparent or not.
OutputFormat
  • This property gets or sets the desired output format for the map being requested from the WMS.
  • When requesting a map, a client may specify the output format in which to show the map. Formats are specified as MIME types such as “image/gif” or “image/png”.
Proxy
  • This property gets or sets the proxy used for requesting a Web Response.
TimeoutInSecond
  • This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds.
Crs
  • This property gets or sets the projected or geographic coordinate reference system to be used.
Credentials
  • This property gets or sets the base authentication interface for retrieving credentials for Web Client authentication.
  • Type:ICredentials
Exceptions
  • This property indicates the format in which the client wishes to be notified of service exceptions.
  • Upon receiving a request that is invalid according to the OGC standard, the server shall issue a service exception report. The service report is meant to describe to the client application or its human user the reason(s) that the request is invalid.
  • This property specifies a dictionary used to update the request sent from the client to the WMS server.
AxisOrder
CapabilitesCacheTimeout
  • Type:TimeSpan
Projection
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
IsNegative
IsGrayscale
IsOpen
HasProjectionText
HasProjectionTextCore
SendingWebRequest
  • This event is called before sending the reqeust for raster image.
  • This event is called before sending the reqeust for raster image. It is typical that user want to get the url of reqeust and modify it according to their requirements. For example, user could create a signiture for it, and verify it on the server side.
Event Arguments:SendingWebRequestEventArgs
SentWebRequest
  • This event is called after sent the request for raster image and the HttpWebResponse has come back.
Event Arguments:SentWebRequestEventArgs
OpeningRasterSource
Event Arguments:OpeningRasterSourceEventArgs
OpenedRasterSource
Event Arguments:OpenedRasterSourceEventArgs
ClosingRasterSource
Event Arguments:ClosingRasterSourceEventArgs
ClosedRasterSource
Event Arguments:ClosedRasterSourceEventArgs
thinkgeo.mapsuite.portablecore.wmsrastersource.txt · Last modified: 2017/03/16 21:59 (external edit)
