thinkgeo.mapsuite.portablecore.wmsrasterlayer
ThinkGeo.MapSuite.Core.WmsRasterLayer
Represents an object that encapsulates a Web Map Service (WMS) layer.
      • ThinkGeo.MapSuite.Core.RasterLayer
        • ThinkGeo.MapSuite.Core.WmsRasterLayer
WmsRasterLayer()
  • This is the constructor the for the class. If you use this constructor, then you need to set the required properties manually.
  • None
WmsRasterLayer(Uri)
  • This constructor initializes a new layer, then downloads and parses the service description. In an ASP.NET application, the service description is automatically cached for 24 hours when it is not specified.
  • uri
    • Type:Uri
    • Description:URI of the WMS server.
WmsRasterLayer(Uri,GeoWebProxy)
  • uri
    • Type:Uri
  • proxy
    • Description:Proxy to use for the current WMS layer.
GetServerLayerNames()
  • This method returns the names of all layers at the server side.
  • None.
  • Type:Collection<String>
  • Description:This method returns the names of all layers at the server side.
GetServerStyleNames()
  • This method returns the names of all styles at the server side.
  • None.
  • Description:This method returns the names of all styles at the server side.
GetServerOutputFormats()
  • This method returns the output format at the server side.
  • None.
  • Description:This method returns the output format at the server side.
GetServerCrss()
  • This method returns the projected or geographic coordinate reference systems to be used.
GetServerExceptionFormats()
  • This method returns the exception format at the server side.
  • None.
  • Description:This method returns the exception format at the server side.
GetServiceVersion()
  • This API gets the WMS server version of the service.
  • Description:Returning a string reflecting the version of the service in WMS.
GetServerFeatureInfoFormats()
  • This API gets the WMS server FeatureInfo formats of the service.
  • Description:This API returns the FeatureInfo formats supported on the server-side.
GetServerCapabilitiesXml()
  • This API gets the GetCapabilites document of the service.
  • Description:This API returns the GetCapabilites document of the service.
GetRequestUrl(RectangleShape,Int32,Int32)
  • Get the request URL from the client to the WMS.
  • Description:The request URL from the client to the WMS.
  • canvasWidth
    • Description:The returning map width, as well as the drawing canvas width.
  • canvasHeight
    • Description:The returning map height, as well as the drawing canvas height.
GetFeatureInfo(ScreenPointF)
GetFeatureInfo(ScreenPointF,String)
  • infoFormat
GetFeatureInfo(ScreenPointF,Int32)
  • maxFeatures
GetFeatureInfo(ScreenPointF,String,Int32)
  • infoFormat
  • maxFeatures
GetProjectionText()
GetHorizontalResolution()
  • Type:Single
GetVerticalResolution()
  • Type:Single
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetRequestUrlCore(RectangleShape,Int32,Int32)
  • canvasWidth
  • canvasHeight
GetBoundingBoxCore()
OpenCore()
CloseCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
Uri
  • This property specifies the URI of the WMS server.
  • Type:Uri
ActiveLayerNames
  • This property represents the available layers that can be requested from the client and shown on the map.
  • When requesting a map, a client may specify the layers to be shown on the map.
ActiveStyleNames
  • This property represents the available styles that can be requested from the client and shown on the map.
  • When requesting a map, a client may specify the styles to be shown on the map.
OutputFormat
  • This property gets or sets the desired output format for the map requested from the WMS.
  • When requesting a map, a client may specify the output format in which to show the map. Format are specified as MIME types such as “image/gif” or “image/png”.
Credentials
  • This property gets or sets the base authentication interface for retrieving credentials for Web Client authentication.
  • Type:ICredentials
IsTransparent
  • This property gets or sets whether the response map image's background color is transparent or not.
Proxy
  • This property gets or sets the proxy used for requesting a Web Response.
Crs
  • This property gets or sets the projected or geographic coordinate reference system to be used.
TimeoutInSecond
  • This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds.
Exceptions
  • This property indicates the format in which the client wishes to be notified of service exceptions.
  • Upon receiving a request that is invalid according to the OGC standard, the server shall issue a service exception report. The service report is meant to describe to the client application or its human user the reason(s) that the request is invalid.
CapabilitesCacheTimeOut
  • Type:TimeSpan
  • This property specifies a dictionary used to update the request sent from the client to the WMS server.
HasBoundingBox
  • This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs.
  • The override in the WmsRasterLayer sets it to true.
AxisOrder
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
IsNegative
IsGrayscale
ImageSource
UpperThreshold
LowerThreshold
HasProjectionText
KeyColors
IsOpen
DrawingTime
  • Type:TimeSpan
IsVisible
Transparency
  • Type:Single
DrawingExceptionMode
Attribution
RequestDrawingInterval
  • Type:TimeSpan
IsOpenCore
SendingWebRequest
Event Arguments:SendingWebRequestEventArgs
SentWebRequest
Event Arguments:SentWebRequestEventArgs
DrawingException
DrawnException
DrawingAttribution
DrawnAttribution
RequestedDrawing
RequestingDrawing
thinkgeo.mapsuite.portablecore.wmsrasterlayer.txt · Last modified: 2017/03/16 21:59 (external edit)
