thinkgeo.mapsuite.portablecore.shapevalidationresult
ThinkGeo.MapSuite.Core.ShapeValidationResult
    • System.ValueType
      • ThinkGeo.MapSuite.Core.ShapeValidationResult
ShapeValidationResult(Boolean,String)
  • This constructor allows you to set the IsValid and ValidationErrors properties.
  • None
  • isValid
    • Description:This parameter describes whether the object has passed its validation method.
  • validationErrors
    • Description:This parameter describes the list of errors if the object did not pass its validation method. The errors are separated by semicolons.
  • This method is an override of the Equals functionality.
  • None
  • This method is an override of the GetHashCode functionality.
  • None
IsValid
  • This property describes whether the object has passed its validation method.
  • None
ValidationErrors
  • This property describes the list of errors if the object did not pass its validation method.
  • If there are multiple errors, they will be separated by semicolons. If the object passed its validations, then this string will be empty.
thinkgeo.mapsuite.portablecore.shapevalidationresult.txt · Last modified: 2017/03/16 21:59 (external edit)
