thinkgeo.mapsuite.portablecore.regexitem
ThinkGeo.MapSuite.Core.RegexItem
This class represents a single Regex Match statement and styles to draw.
    • ThinkGeo.MapSuite.Core.RegexItem
RegexItem()
  • If you use this constructor, you should set the necessary properties manually.
RegexItem(String,AreaStyle)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultAreaStyle.
  • regularExpression
    • Description:This parameter is the regular expression statement you would like to match.
  • areaStyle
    • Type:AreaStyle
    • Description:This parameter is the style you want to draw with if the regular expression matches.
RegexItem(String,LineStyle)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultLineStyle.
  • regularExpression
  • lineStyle
    • Type:LineStyle
RegexItem(String,PointStyle)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultPointStyle.
  • regularExpression
  • pointStyle
RegexItem(String,TextStyle)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultTextStyle.
  • regularExpression
  • textStyle
    • Type:TextStyle
RegexItem(String,Collection<Style>)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the CustomStyles.
  • regularExpression
  • styles
    • Type:Collection<Style>
    • Description:This parameter represents the styles you want to draw with if the regular expression matches.
RegularExpression
  • This property gets and sets the regular expression text used for matching.
  • This should be a valid regular expression string. Formatting regular expression strings is outside the scope of this documentation; however, there are many useful resources on the web for learning about regular expressions.
CustomStyles
  • This property gets the collection of custom styles.
  • The custom styles allow you to use styles other than the default style properties of the class. In this way, you can use a DotDensityStyle or any other style in the API.
DefaultAreaStyle
  • This property gets and sets the default AreaStyle. You should use this style if your features are area-based.
  • The default style allows you to directly set properties on the styles without having to create a new style each time. You can start simply by setting properties like color, etc. This makes modifying styles very easy.
DefaultLineStyle
  • This property gets and sets the default LineStyle. You should use this style if your features are line-based.
DefaultPointStyle
  • This property gets and sets the default PointStyle. You should use this style if your features are point-based.
DefaultTextStyle
  • This property gets and sets the default TextStyle. You should use this style if your features are text-based (such as labels).
thinkgeo.mapsuite.portablecore.regexitem.txt · Last modified: 2017/03/16 21:59 (external edit)
