This is the constructor the for the class. If you use this constructor, then you need to set the required properties manually.
None.
QualityFamilyAreaStyle(GeoPen,GeoColor,Int32,PenBrushDrawingOrder)
None.
This method clears the cached style in the cache.
None.
This gets the cached style in the class. The key of the style in the cache is feature.Id & feature.GetHashCode().
None.
