<!– Class –>
*System.Object ThinkGeo.MapSuite.PortableCore.Layer *ThinkGeo.MapSuite.PortableCore.AdornmentLayer ThinkGeo.MapSuite.PortableCore.MagneticDeclinationAdornmentLayer
MagneticDeclinationAdornmentLayer | |||
MagneticDeclinationAdornmentLayer | ScreenPointF | ||
MagneticDeclinationAdornmentLayer | AdornmentLocation | ||
MagneticDeclinationAdornmentLayer | String, AdornmentLocation |
CloneDeep | Layer | Create a copy of Layer using the deep clone process. | |
Close | Layer | This method closes the Layer and releases any resources it was using. | |
Draw | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
GetBoundingBox | Layer | This method returns the bounding box of the Layer. | |
GetDrawingLocation | GeoCanvas, Single, Single | AdornmentLayer(overriden) | |
![]() GetMagneticDeclination | Feature, Double, DistanceUnit, DateTime | ||
![]() GetMagneticDeclination | Feature, Double, DistanceUnit, DateTime, String | ||
![]() GetMagneticDeclination | Feature, Double, DistanceUnit, DateTime, Stream | ||
![]() GetMagneticDeclination | Double, Double, Double, DistanceUnit, DateTime, Stream | ||
![]() GetMagneticDeclination | Double, Double, Double, DistanceUnit, DateTime, String | ||
![]() GetMagneticDeclination | Double, Double, Double, DistanceUnit, DateTime | ||
![]() GetMagneticDeclination | PointShape, Double, DistanceUnit, DateTime, Stream | ||
![]() GetMagneticDeclination | PointShape, Double, DistanceUnit, DateTime | ||
![]() GetMagneticDeclination | PointShape, Double, DistanceUnit, DateTime, String | ||
Open | Layer | This method opens the Layer so that it is initialized and ready to use. | |
RequestDrawing | TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape> | Layer | |
RequestDrawing | RectangleShape | Layer | |
RequestDrawing | Layer | ||
RequestDrawing | RectangleShape, TimeSpan | Layer | |
RequestDrawing | IEnumerable<RectangleShape>, TimeSpan | Layer | |
CloseCore | Layer(overriden) | ||
DrawCore | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | |
DrawExceptionCore | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
GetBoundingBoxCore | Layer | This method returns the bounding box of the Layer. | |
MemberwiseClone | Object | ||
OnStreamLoading | StreamLoadingEventArgs | This method allows you to raise the StreamLoading event. | |
OpenCore | Layer(overriden) |
BackgroundMask | AreaStyle | AdornmentLayer | |
Elevation | Double | ||
ElevationUnit | DistanceUnit | ||
GridNorthLineStyle | LineStyle | ||
HasBoundingBox | Boolean | Layer | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
Height | Single | AdornmentLayer | |
Location | AdornmentLocation | AdornmentLayer | This property gets and sets the drawing location of the AdornmentLayer. |
MagneticFieldPathFilename | String | International Geomagnetic Reference Field (IGRF-11) | |
MagneticNorthLineStyle | LineStyle | ||
ProjectionToDecimalDegrees | Projection | ||
SampleDateTime | DateTime | ||
TextStyle | TextStyle | ||
TrueNorthLineStyle | LineStyle | ||
TrueNorthPointStyle | PointStyle | ||
Width | Single | AdornmentLayer | |
XOffsetInPixel | Single | AdornmentLayer | This property gets and sets the X pixel offset for the AdornmentLayer. |
YOffsetInPixel | Single | AdornmentLayer | This property gets and sets the Y pixel offset for the AdornmentLayer. |
IsOpenCore | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
StreamLoading | StreamLoadingEventArgs | This event allows you to pass in your own stream to represent the image. |
| startPoint | ScreenPointF<!– ThinkGeo.MapSuite.PortableCore.ScreenPointF –> |
| adornmentLocation | AdornmentLocation<!– ThinkGeo.MapSuite.PortableCore.AdornmentLocation –> |
| magneticFieldPathFilename | String<!– System.String –> | |
| Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
| labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
| RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
| adornmentWidth | Single<!– System.Single –> | |
| adornmentHeight | Single<!– System.Single –> |
<!– ThinkGeo.MapSuite.PortableCore.AdornmentLayer(overriden) –> Go Back
<!– static –>
| MagneticDeclination<!– ThinkGeo.MapSuite.PortableCore.MagneticDeclination –> |
| pointFeature | Feature<!– ThinkGeo.MapSuite.PortableCore.Feature –> | |
| elevation | Double<!– System.Double –> | |
| elevationUnit | DistanceUnit<!– ThinkGeo.MapSuite.PortableCore.DistanceUnit –> | |
| sampleDateTime | DateTime<!– System.DateTime –> |
<!– ThinkGeo.MapSuite.PortableCore.MagneticDeclinationAdornmentLayer –> Go Back
<!– static –>
| sampleDateTime | DateTime<!– System.DateTime –> | |
<!– static –>
| magneticFieldStream | Stream<!– System.IO.Stream –> |
<!– static –>
| x | Double<!– System.Double –> | |
| y | Double<!– System.Double –> | |
<!– static –>
<!– static –>
<!– static –>
| point | PointShape<!– ThinkGeo.MapSuite.PortableCore.PointShape –> | |
<!– static –>
<!– static –>
| bufferTime | TimeSpan<!– System.TimeSpan –> |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> |
| extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
| extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
| canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
| args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
| e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
| e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
| args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
| e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
| eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
| eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
This method allows you to raise the StreamLoading event. Normally events are not accessible to derived classes, so we exposed a way to raise the event as necessary through this protected method.
| e | StreamLoadingEventArgs<!– ThinkGeo.MapSuite.PortableCore.StreamLoadingEventArgs –> | This parameter represents the event arguments you want to raise the StreamLoading event with. |
| AreaStyle<!– ThinkGeo.MapSuite.PortableCore.AreaStyle –> |
<!– ThinkGeo.MapSuite.PortableCore.AdornmentLayer –> Go Back
| DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
| LineStyle<!– ThinkGeo.MapSuite.PortableCore.LineStyle –> |
The default value is false.
| Projection<!– ThinkGeo.MapSuite.PortableCore.Projection –> |
| TextStyle<!– ThinkGeo.MapSuite.PortableCore.TextStyle –> |
| PointStyle<!– ThinkGeo.MapSuite.PortableCore.PointStyle –> |
This property allows you to specify an X offset. It is useful, when combined with a Y offset, to do things like modify the location of the adornment.
This property allows you to specify a Y offset. It is useful, when combined with an X offset, to do things like modify the location of the adornment.
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
