thinkgeo.mapsuite.portablecore.linksource
ThinkGeo.MapSuite.Core.LinkSource
LinkSource()
Open()
Close()
GetColumns()
OpenCore()
CloseCore()
GetColumnsCore()
Records
Id
IsOpen
LinkExpressions
  • Type:Collection<String>
LinkSources
ColumnNamesToExclude
IsCacheEnabled
EhY=
thinkgeo.mapsuite.portablecore.linksource.txt · Last modified: 2017/03/16 21:59 (external edit)
