thinkgeo.mapsuite.portablecore.layersdrawneventargs
ThinkGeo.MapSuite.Core.LayersDrawnEventArgs
      • ThinkGeo.MapSuite.Core.LayersDrawnEventArgs
LayersDrawnEventArgs()
LayersDrawnEventArgs(IEnumerable<Layer>,RectangleShape,Object)
  • None
  • layers
    • Type:IEnumerable<Layer>
    • Description:This parameter is the layers that were drawn.
  • worldExtent
    • Description:This parameter is the world extent you are drawing.
  • nativeImage
    • Description:This parameter is the GeoImage or native map image.
WorldExtent
  • This property gets and sets the world extent to draw.
  • None
NativeImage
  • This property gets and sets the GeoImage or native image we are drawing on.
  • None
Layers
  • This property gets and sets the layers that have been drawn.
  • None
thinkgeo.mapsuite.portablecore.layersdrawneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
