thinkgeo.mapsuite.core.buildingindexdelimitedfeaturesourceeventargs
ThinkGeo.MapSuite.Core.BuildingIndexDelimitedFeatureSourceEventArgs
This class represents the parameters passed in through the BuildingIndex event in BuildingIndexDelimitedFeatureSourceEventArgs class.
      • ThinkGeo.MapSuite.Core.BuildingIndexDelimitedFeatureSourceEventArgs
BuildingIndexDelimitedFeatureSourceEventArgs(Int32,Int32,Feature,DateTime,String)
  • recordCount
  • currentRecordIndex
  • currentFeature
  • startProcessTime
    • Type:DateTime
  • delimitedPathFilename
RecordCount
Gets the total record count to build rTree index.
CurrentRecordIndex
Gets the current record index for building rTree index.
CurrentFeature
Gets the current feature for building rTree index.
StartProcessTime
Gets the starting process time for building the index.
  • Type:DateTime
DelimitedPathFilename
Gets the delimited path file name.
Cancel
Gets or sets to see if we need to cancel the building index of current record.
thinkgeo.mapsuite.core.buildingindexdelimitedfeaturesourceeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
