thinkgeo.mapsuite.portablecore.labelingcandidate
ThinkGeo.MapSuite.Core.LabelingCandidate
This class represents a candidate for labeling.
LabelingCandidate()
  • If you use this constructor, then you should set the applicable properties manually.
LabelingCandidate(String,PolygonShape,PointShape)
  • None
  • originalText
    • Description:This parameter represents the text of the label before it is potentially modified.
  • simplePolygonInScreenCoordinates
    • Description:This parameter is a polygon (in screen coordinates) representing the area to be labeled.
  • centerPointInScreenCoordinates
    • Description:This parameter is the center of the polygon (in screen coordinates) representing the area to be labeled.
LabelingCandidate(String,PolygonShape,PointShape,Collection<LabelInformation>)
  • None
  • originalText
  • labelInformation
    • Type:Collection<LabelInformation>
    • Description:This parameter is the labeling information for this labeling candidate.
OriginalText
  • This property gets and sets the original text for the label.
  • None
ScreenArea
  • This property gets and sets the screen area that encompasses the label.
  • None
CenterPoint
  • This property gets and sets the center point for the center of the label.
  • None
LabelInformation
  • This property gets and sets the label information for this label.
  • None
thinkgeo.mapsuite.portablecore.labelingcandidate.txt · Last modified: 2017/03/16 21:59 (external edit)
