<!– Class –>
![]() ![]() | AdornmentLayer, String | ||
![]() ![]() | RasterLayer, String | ||
![]() ![]() | FeatureLayer, String | ||
![]() ![]() | IEnumerable<Layer>, String | ||
![]() ![]() | IEnumerable<MapShape>, String | ||
![]() | Layer | Create a copy of Layer using the deep clone process. | |
![]() | Layer | This method closes the Layer and releases any resources it was using. | |
![]() ![]() | String | ||
![]() ![]() | String, IEnumerable<MapShape>, KmlFileType | ||
![]() ![]() | String, IEnumerable<MapShape> | ||
![]() ![]() | String, RasterLayer, KmlFileType | ||
![]() ![]() | String, RasterLayer | ||
![]() ![]() | String, FeatureLayer, KmlFileType, Encoding | ||
![]() ![]() | String, FeatureLayer, KmlFileType | ||
![]() ![]() | String, FeatureLayer | ||
![]() ![]() | String, Encoding | ||
![]() ![]() | String, IEnumerable<MapShape>, KmlFileType, Encoding | ||
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
![]() | Object | Object | |
![]() | Layer | This method returns the bounding box of the Layer. | |
![]() | Object | ||
![]() | Object | ||
![]() | Layer | This method opens the Layer so that it is initialized and ready to use. | |
![]() | Layer | ||
![]() | RectangleShape | Layer | |
![]() | IEnumerable<RectangleShape> | Layer | |
![]() | RectangleShape, TimeSpan | Layer | |
![]() | IEnumerable<RectangleShape>, TimeSpan | Layer | |
![]() | TimeSpan | Layer | |
![]() | Object |
![]() | String | Layer | |
![]() | DrawingExceptionMode | Layer | Gets or sets the DrawExcpetionMode when exception happens. |
![]() | TimeSpan | Layer | This property gets the last drawing time for the layer. |
![]() | Encoding | ||
![]() | Boolean | Layer(overriden) | |
![]() | Boolean | Layer | This property gets and sets if the image should be converted to grayscale. |
![]() | Boolean | Layer | This property gets and sets whether the image should be converted to negative (inverse colors). |
![]() | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
![]() | Boolean | Layer | This property gets and set the visible state of the layer. |
![]() | String | ||
![]() | String | Layer | This property gets and sets the name for the layer. |
![]() | Single | Layer | This property gets and sets the amount of transparency to apply to the image. |
Name | Type | Description |
kmlPathFilename | String<!– System.String –> |
kmlPathFilename | String<!– System.String –> | |
encoding | Encoding<!– System.Text.Encoding –> |
<!– static –>
Return Type | Description |
Void<!– System.Void –> |
adormentLayer | AdornmentLayer<!– ThinkGeo.MapSuite.PortableCore.AdornmentLayer –> | |
pathFilename | String<!– System.String –> |
<!– ThinkGeo.MapSuite.PortableCore.KmlLayer –> Go Back
<!– static –>
rasterLayer | RasterLayer<!– ThinkGeo.MapSuite.PortableCore.RasterLayer –> | |
<!– static –>
featureLayer | FeatureLayer<!– ThinkGeo.MapSuite.PortableCore.FeatureLayer –> | |
<!– static –>
layers | IEnumerable<Layer><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.Layer} –> | |
<!– static –>
MapShapes | IEnumerable<MapShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.MapShape} –> | |
Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
<!– static –>
<!– static –>
pathFilename | String<!– System.String –> | |
mapShapes | IEnumerable<MapShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.MapShape} –> | |
kmlFileType | KmlFileType<!– ThinkGeo.MapSuite.PortableCore.KmlFileType –> |
<!– static –>
<!– static –>
<!– static –>
<!– static –>
kmlFileType | KmlFileType<!– ThinkGeo.MapSuite.PortableCore.KmlFileType –> | |
<!– static –>
<!– static –>
<!– static –>
<!– static –>
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
bufferTime | TimeSpan<!– System.TimeSpan –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
Create a copy of Layer using the deep clone process. The default implemenation uses serialization.
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
attribution | String<!– System.String –> |
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
e | Exception<!– System.Exception –> | The exception thrown when layer.Draw(). |
args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
Return Type |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Single<!– System.Single –> |
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
StreamLoadingEventArgs<!– ThinkGeo.MapSuite.PortableCore.StreamLoadingEventArgs –> |
