thinkgeo.mapsuite.portablecore.gridfeaturelayer
ThinkGeo.MapSuite.Core.GridFeatureLayer
This class uses the grid file provided.
      • ThinkGeo.MapSuite.Core.FeatureLayer
        • ThinkGeo.MapSuite.Core.GridFeatureLayer
GridFeatureLayer()
  • This is the default constructor for the class.
GridFeatureLayer(String)
  • This constructor gets the layer ready to use.
  • gridPathFilename
    • Description:This parameter is the path and filename of the grid file you want to use.
GenerateGridMatrix()
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GenerateGrid(GridDefinition,GridInterpolationModel,Stream)
  • outputStream
    • Type:Stream
GenerateGridMatrix(GridDefinition,GridInterpolationModel)
GetBoundingBoxCore()
  • This method returns the bounding box of the FeatureLayer.
  • This method is called from the concrete public method GetBoundingBox. It returns the bounding box of the FeatureLayer.
  • Description:This method returns the bounding box of the FeatureLayer.
SetupTools()
SetupToolsCore()
OpenCore()
CloseCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
PathFilename
  • This property gets and sets the path and filename to the grid file you want to use.
  • This should be the complete path and filename of a grid file.
CellSize
  • Gets the cell size from the grid.
NumberOfColumns
  • Gets the column number from the grid.
NumberOfRows
  • Gets the row number from the grid.
NoDataValue
  • Gets the NoDataValue from the grid.
HasBoundingBox
  • This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In GridFeatureLayer, we override this API and mark it as true.
  • The default implementation in the base class returns false.
DataValueColumnName
WrappingExtent
WrappingMode
EditTools
FeatureIdsToExclude
  • Type:Collection<String>
QueryTools
MaxRecordsToDraw
DrawingMarginInPixel
  • Type:Single
FeatureSource
DrawingQuality
ZoomLevelSet
DrawingMarginPercentage
IsOpen
DrawingTime
  • Type:TimeSpan
IsVisible
Transparency
  • Type:Single
IsNegative
IsGrayscale
DrawingExceptionMode
Attribution
RequestDrawingInterval
  • Type:TimeSpan
FetchedCount
  • Type:Int64
FetchedBytes
  • Type:Int64
StyleTime
  • Type:TimeSpan
FetchTime
  • Type:TimeSpan
IsOpenCore
StreamLoading
DrawingFeatures
DrawingException
DrawnException
DrawingAttribution
DrawnAttribution
RequestedDrawing
RequestingDrawing
thinkgeo.mapsuite.portablecore.gridfeaturelayer.txt · Last modified: 2017/03/16 21:59 (external edit)
