thinkgeo.mapsuite.portablecore.geotiffrasterlayer
ThinkGeo.MapSuite.Core.GeoTiffRasterLayer
This class represents a TIFF image to be drawn on the map.
      • ThinkGeo.MapSuite.Core.RasterLayer
        • ThinkGeo.MapSuite.Core.GeoTiffRasterLayer
GeoTiffRasterLayer()
  • If you use this constructor then, you need to set the PathFileName property manually before using the layer.
GeoTiffRasterLayer(String)
  • This constructor gets the layer ready to use.
  • imagePathFilename
    • Description:This parameter is the path and filename of the TIFF file you want to use.
GeoTiffRasterLayer(String,String)
  • imagePathFilename
  • worldfilePathFilename
    • Description:This parameter is the world file path and filename for the TIFF file you want to use.
GeoTiffRasterLayer(String,RectangleShape)
  • imagePathFilename
  • imageExtent
    • Description:This parameter is the image extent of the TIFF file you want to use.
GetProjectionText()
GetHorizontalResolution()
  • Type:Single
GetVerticalResolution()
  • Type:Single
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetBoundingBoxCore()
OpenCore()
CloseCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
LibraryType
HasBoundingBox
  • This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In GeoTiffRasterLayer, we override this API and mark it as true.
  • The default implementation in the base class returns false.
DrawingQuality
PathFilename
  • This property gets and sets the path and filename of the TIFF file you want to use.
  • This should be the complete path and filename for a TIFF file.
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
IsNegative
IsGrayscale
ImageSource
UpperThreshold
LowerThreshold
HasProjectionText
KeyColors
IsOpen
DrawingTime
  • Type:TimeSpan
IsVisible
Transparency
  • Type:Single
DrawingExceptionMode
Attribution
RequestDrawingInterval
  • Type:TimeSpan
IsOpenCore
DrawingException
DrawnException
DrawingAttribution
DrawnAttribution
RequestedDrawing
RequestingDrawing
thinkgeo.mapsuite.portablecore.geotiffrasterlayer.txt · Last modified: 2017/03/16 21:59 (external edit)
