thinkgeo.mapsuite.portablecore.geocollection_t
Table of Contents
ThinkGeo.MapSuite.PortableCore.GeoCollection‹T›
<!– Class –> This class is a collection with some methods specialized for dealing with Layers and other spatial classes.
We have added some helpful methods like MoveUp, MoveDown, etc. These help when you are manipulating Layers.
Public MethodGeoCollection‹T› This is the default constructor for the class.
Public MethodAdd String, T GeoCollection<T> This method adds an item to the collection by specifying the item and a key.
Public MethodAdd T Collection<T> This method adds an item to the collection.
Public MethodAdd T GeoCollection<T> This method adds an item to the collection.
Public MethodClear Collection<T>
Public MethodContains T Collection<T>
Public MethodContains String GeoCollection<T> This method returns whether an item is in the collection based on the specified key.
Public MethodCopyTo T[], Int32 Collection<T>
Public MethodGetEnumerator Collection<T>
Public MethodGetKeys GeoCollection<T> This method returns a collection of the keys in the collection.
Public MethodGetType Object
Public MethodIndexOf T Collection<T>
Public MethodInsert Int32, T Collection<T> Inserts an element into the System.Collections.ObjectModel.Collection<T> at the specified index.
Public MethodInsert Int32, T GeoCollection<T> Inserts an element into the System.Collections.ObjectModel.Collection<T> at the specified index.
Public MethodInsert Int32, String, T GeoCollection<T> Inserts an element into the System.Collections.ObjectModel.Collection<T> at the specified index and key.
Public MethodMoveDown String GeoCollection<T> This method moves an item down in the collection.
Public MethodMoveDown T GeoCollection<T> This method moves an item down in the collection.
Public MethodMoveDown Int32 GeoCollection<T> This method moves an item down in the collection.
Public MethodMoveTo T, Int32 GeoCollection<T> This method moves the item you specified to the location of toIndex in the collection.
Public MethodMoveTo String, Int32 GeoCollection<T> This method moves the item with the key you specified to the location of toIndex in the collection.
Public MethodMoveTo Int32, Int32 GeoCollection<T> This method moves the item at fromIndex to the location of toIndex in the collection.
Public MethodMoveToBottom T GeoCollection<T> This method moves the item specified key to the bottom of the collection.
Public MethodMoveToBottom Int32 GeoCollection<T> This method moves the item at the specified index to the bottom of the collection.
Public MethodMoveToBottom String GeoCollection<T> This method moves the item with the specified key to the bottom of the collection.
Public MethodMoveToTop T GeoCollection<T> This method moves the item specified to the top of the collection.
Public MethodMoveToTop String GeoCollection<T> This method moves the item with the specified key to the top of the collection.
Public MethodMoveToTop Int32 GeoCollection<T> This method moves the item at the specified index to the top of the collection.
Public MethodMoveUp T GeoCollection<T> This method moves an item up in the collection.
Public MethodMoveUp String GeoCollection<T> This method moves an item up in the collection.
Public MethodMoveUp Int32 GeoCollection<T> This method moves an item up in the collection.
Public MethodRemove String GeoCollection<T> This method removes an item from the collection based on the specified key.
Public MethodRemove T Collection<T>
Public MethodRemoveAt Int32 Collection<T>
Public MethodToString Object
Protected MethodClearItems Collection<T>(overriden) This method clears the items from the collection.
Protected MethodInsertItem Int32, T Collection<T>(overriden)
Protected MethodOnAdded AddedGeoCollectionEventArgs GeoCollection<T>
Protected MethodOnAdding AddingGeoCollectionEventArgs GeoCollection<T>
Protected MethodOnClearedItems ClearedItemsGeoCollectionEventArgs GeoCollection<T>
Protected MethodOnClearingItems ClearingItemsGeoCollectionEventArgs GeoCollection<T>
Protected MethodOnCollectionChanged NotifyCollectionChangedEventArgs GeoCollection<T>
Protected MethodOnInserted InsertedGeoCollectionEventArgs GeoCollection<T>
Protected MethodOnInserting InsertingGeoCollectionEventArgs GeoCollection<T>
Protected MethodOnPropertyChanged PropertyChangedEventArgs GeoCollection<T>
Protected MethodOnRemoved RemovedGeoCollectionEventArgs GeoCollection<T>
Protected MethodOnRemoving RemovingGeoCollectionEventArgs GeoCollection<T>
Protected MethodRemoveItem Int32 Collection<T>(overriden) This method removes an item from the collection based on the specified index.
Protected MethodSetItem Int32, T Collection<T>(overriden) This method allows you to set an item based on the index.
Public PropertyCount Int32 Collection<T>
Public PropertyItem T GeoCollection<T>
Public PropertyItem T Collection<T>
Protected PropertyItems IList<T> Collection<T>
GeoCollection‹T›()
Name Type Description
Go Back
Add(String, T)
Return Type Description
Void<!– System.Void –>
key String<!– System.String –> This parameter is the key to find the item.
item T<!– T –> This parameter is the item you want added to the collection.
<!– ThinkGeo.MapSuite.PortableCore.GeoCollection{T} –> Go Back
Add(T)
This method adds an item to the collection, and the item's key will be a random GUID.
<!– Collection{T} –> Go Back
Add(T)
Clear()
Contains(T)
Boolean<!– System.Boolean –>
item T<!– T –>
Contains(String)
Boolean<!– System.Boolean –> This method returns whether an item is in the collection based on the specified key.
key String<!– System.String –> This parameter is the key of the item you are searching for.
CopyTo(T[], Int32)
array T[]<!– Tthinkgeo.mapsuite.portablecore.geocollection_t –>
index Int32<!– System.Int32 –>
GetEnumerator()
IEnumerator<T><!– IEnumerator{T} –>
GetKeys()
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> This method returns a collection of the keys in the collection.
Type<!– System.Type –>
IndexOf(T)
item T<!– T –>
Insert(Int32, T)
index Int32<!– System.Int32 –> The zero-based index at which item should be inserted.
item T<!– T –> The object to insert. The value can be null for reference types.
Insert(Int32, T)
Insert(Int32, String, T)
key String<!– System.String –> The key to find the item.
MoveDown(String)
key String<!– System.String –> This parameter is the key of the item in the dictionary.
MoveDown(T)
item T<!– T –> This parameter is the item you want to move down in the dictionary.
MoveDown(Int32)
index Int32<!– System.Int32 –> This parameter is the index of the item in the collection.
MoveTo(T, Int32)
item T<!– T –> This parameter is the item you want to move in the collection.
toIndex Int32<!– System.Int32 –> This parameter is the target index that you want to move the item to in the collection.
MoveTo(String, Int32)
key String<!– System.String –> This parameter is the key of item you want to move in the collection.
MoveTo(Int32, Int32)
fromIndex Int32<!– System.Int32 –> This parameter is the index of the item you want move from in the collection.
MoveToBottom(T)
item T<!– T –> This parameter is the item you want move to the bottom of the collection.
MoveToBottom(Int32)
index Int32<!– System.Int32 –> This parameter is the index of the item you want move to the bottom of the collection.
MoveToBottom(String)
key String<!– System.String –> This parameter is the key of the item you want move to the bottom of the collection.
MoveToTop(T)
item T<!– T –> This parameter is the item you want move to the top of the collection.
MoveToTop(String)
key String<!– System.String –> This parameter is the key of the item you want move to the top of the collection.
MoveToTop(Int32)
index Int32<!– System.Int32 –> This parameter is the index of the item you want move to the top of the collection.
MoveUp(T)
item T<!– T –> This parameter is the item you want to move up in the collection.
MoveUp(String)
key String<!– System.String –> This parameter is the key of the item in the collection.
MoveUp(Int32)
Remove(String)
key String<!– System.String –> This parameter is the key of the item you want to remove.
Remove(T)
item T<!– T –>
RemoveAt(Int32)
ClearItems()
<!– Collection{T}(overriden) –> Go Back
InsertItem(Int32, T)
item T<!– T –>
OnAdded(AddedGeoCollectionEventArgs)
e AddedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.PortableCore.AddedGeoCollectionEventArgs –>
OnAdding(AddingGeoCollectionEventArgs)
e AddingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.PortableCore.AddingGeoCollectionEventArgs –>
OnClearedItems(ClearedItemsGeoCollectionEventArgs)
e ClearedItemsGeoCollectionEventArgs<!– ThinkGeo.MapSuite.PortableCore.ClearedItemsGeoCollectionEventArgs –>
OnClearingItems(ClearingItemsGeoCollectionEventArgs)
e ClearingItemsGeoCollectionEventArgs<!– ThinkGeo.MapSuite.PortableCore.ClearingItemsGeoCollectionEventArgs –>
OnCollectionChanged(NotifyCollectionChangedEventArgs)
e NotifyCollectionChangedEventArgs<!– System.Collections.Specialized.NotifyCollectionChangedEventArgs –>
OnInserted(InsertedGeoCollectionEventArgs)
e InsertedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.PortableCore.InsertedGeoCollectionEventArgs –>
OnInserting(InsertingGeoCollectionEventArgs)
e InsertingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.PortableCore.InsertingGeoCollectionEventArgs –>
OnPropertyChanged(PropertyChangedEventArgs)
e PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –>
OnRemoved(RemovedGeoCollectionEventArgs)
e RemovedGeoCollectionEventArgs<!– ThinkGeo.MapSuite.PortableCore.RemovedGeoCollectionEventArgs –>
OnRemoving(RemovingGeoCollectionEventArgs)
e RemovingGeoCollectionEventArgs<!– ThinkGeo.MapSuite.PortableCore.RemovingGeoCollectionEventArgs –>
RemoveItem(Int32)
index Int32<!– System.Int32 –> This parameter is the index of the item you want to remove.
SetItem(Int32, T)
index Int32<!– System.Int32 –> This parameter is the index of the item you want to set.
item T<!– T –> This parameter is the item you want to set.
Count
Return Type
Item
Return Type
T<!– T –>
Item
Return Type
T<!– T –>
Items
Return Type
IList<T><!– IList{T} –>
Added
Event Arguments
Event Arguments
Adding
Event Arguments
Event Arguments
ClearedItems
Event Arguments
Event Arguments
ClearingItems
Event Arguments
Event Arguments
CollectionChanged
Event Arguments
Event Arguments
Inserted
Event Arguments
Event Arguments
Inserting
Event Arguments
Event Arguments
PropertyChanged
Event Arguments
Event Arguments
Removed
Event Arguments
Event Arguments
Removing
Event Arguments
Event Arguments
thinkgeo.mapsuite.portablecore.geocollection_t.txt · Last modified: 2017/03/16 21:59 (external edit)
