<!– Class –> This class generates code that recreates any given object.
*System.Object **ThinkGeo.MapSuite.PortableCore.GeoCodeGenerator
GeoCodeGenerator | Creates an instance of GeoCodeGenerator. | ||
GeoCodeGenerator | GeoCodeFormatter |
GenerateCode | Object | Generates code that recreates an object. | |
GenerateCode | Object, String | Generates code that recreates an object. | |
GenerateCode | Object, Stream | Generates code that recreates an object. | |
Formatter | GeoCodeFormatter | Gets or sets the Formatter. The Formatter determines what kind of program code will be generated. |
| formatter | GeoCodeFormatter<!– ThinkGeo.MapSuite.PortableCore.GeoCodeFormatter –> |
| String<!– System.String –> | The generated code. |
| sourceObject | Object<!– System.Object –> | The object to generate code for. |
<!– ThinkGeo.MapSuite.PortableCore.GeoCodeGenerator –> Go Back
| pathFileName | String<!– System.String –> | The path to save the generated code. |
| stream | Stream<!– System.IO.Stream –> | The stream to save the generated code into. |
