<!– Class –> Defines objects used to fill the interiors of AreaBaseShapes, such as MultiPolygonShape, PolygonShape, EllipseShape, and other AreaBaseShapes.
This is an abstract base class and cannot be instantiated. To create a GeoBrush object, use classes derived from GeoBrush, such as GeoSolidBrush.
*System.Object ThinkGeo.MapSuite.PortableCore.GeoBrush *ThinkGeo.MapSuite.PortableCore.GeoHatchBrush *ThinkGeo.MapSuite.PortableCore.GeoLinearGradientBrush *ThinkGeo.MapSuite.PortableCore.GeoSolidBrush ***ThinkGeo.MapSuite.PortableCore.GeoTextureBrush
![]() | This is the constructor for the GeoBrush |
![]() | Create a copy of GeoBrush using the deep clone process. | ||
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | Object |
![]() | Create a copy of GeoBrush using the deep clone process. The default implementation uses serialization. | ||
![]() | Object | ||
![]() | Object |
![]() | Int64 | The id of the GeoBrush. This is always used as a key when in the cached brushes. |
Name | Type | Description |
Return Type | Description |
GeoBrush<!– ThinkGeo.MapSuite.PortableCore.GeoBrush –> | A cloned GeoBrush. |
<!– ThinkGeo.MapSuite.PortableCore.GeoBrush –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
Int64<!– System.Int64 –> |
