thinkgeo.mapsuite.portablecore.drawinglinejoin
ThinkGeo.MapSuite.Core.DrawingLineJoin
  • This enumeration specifies how to join consecutive line or curve segments.
  • None
Items
Miter
  • Summary:Specifies a mitered join. This produces a sharp corner or a clipped corner, depending on whether the length of the miter exceeds the miter limit.
Bevel
  • Summary:Specifies a beveled join. This produces a diagonal corner.
MiterClipped
  • Summary:Specifies a mitered join. This produces a sharp corner or a beveled corner, depending on whether the length of the miter exceeds the miter limit.
Round
  • Summary:Specifies a circular join. This produces a smooth, circular arc between the lines.
thinkgeo.mapsuite.portablecore.drawinglinejoin.txt · Last modified: 2017/03/16 21:59 (external edit)
