thinkgeo.mapsuite.portablecore.degreesminutesseconds
ThinkGeo.MapSuite.Core.DegreesMinutesSeconds
This structure represents a degrees, minutes and seconds value.
    • System.ValueType
      • ThinkGeo.MapSuite.Core.DegreesMinutesSeconds
DegreesMinutesSeconds(Int32,Int32,Double)
  • This constructor allows you to create an instance of the class by specifying the degree, minute and second values.
  • None
  • degrees
    • Description:This parameter represents the degree portion of the structure.
  • minutes
    • Description:This parameter represents the minute portion of the structure.
  • seconds
    • Description:This parameter represents the second portion of the structure.
  • Serves as hash function for the particular type.
  • Description:The hash code for this particular type.
  • Compares current DegreesMinutesSeconds with a passing object.
  • Description:True if the passing object satisfies the following two conditions:1) The object is of DegreesMinutesSeconds type.2) The Degrees, Minutes and Seconds of both DegreesMinutesSeconds should be the same.If both conditions are not met, will return false.
    • Description:The passing object which will be used to compare with current DegreesMinutesSeconds.
Add(DegreesMinutesSeconds)
  • Add two DegreesMinutsSeconds together and return back a summary of the two.
  • targetDegreesMinutesSeconds
  • This method returns a formatted representation of the degrees, minutes and seconds value.
  • The value will be formatted in the standard string format: 75º 21' 28“
  • Description:This method returns a formatted representation of the degrees, minutes and seconds value.
ToString(Int32)
  • This method returns a formatted representation of the degrees, minutes and seconds value that has been rounded to the specified decimals.
  • The value will be formatted in the standard string format. For example, 75º 21' 2.1235” (when the decimals parameter is set to 4).
  • decimals
    • Description:The target decimals that the degrees, minutes, seconds value will be rounded to.
Degrees
  • This property returns the degrees portion of the structure.
  • None
Minutes
  • This property returns the minutes portion of the structure.
  • None
Seconds
  • This property returns the seconds portion of the structure.
  • None
thinkgeo.mapsuite.portablecore.degreesminutesseconds.txt · Last modified: 2017/03/16 21:59 (external edit)
