<!– Class –> This class represents the parameters passed in through the CreatingMemberObject event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.PortableCore.CreatingMemberObjectGeoObjectModelerEventArgs
CreatingMemberObjectGeoObjectModelerEventArgs | Creates an instance of CreatingMemberObjectGeoObjectModelerEventArgs. | ||
CreatingMemberObjectGeoObjectModelerEventArgs | String, Type, Object, GeoObjectNode | Creates an instance of CreatingMemberObjectGeoObjectModelerEventArgs with name, type, owner and node. |
Name | String | Gets or sets the name of the member. | |
Node | GeoObjectNode | Gets or sets the node of the member. | |
Owner | Object | Gets or sets the owner of the member. | |
Type | Type | Gets or sets the type of the member. |
| name | String<!– System.String –> | The name of the member. |
| type | Type<!– System.Type –> | |
| owner | Object<!– System.Object –> | The owner of the member. |
| node | GeoObjectNode<!– ThinkGeo.MapSuite.PortableCore.GeoObjectNode –> | The node of the member. |
<!– ThinkGeo.MapSuite.PortableCore.CreatingMemberObjectGeoObjectModelerEventArgs –> Go Back
