thinkgeo.mapsuite.portablecore.createdmembernodegeoobjectmodelereventargs
ThinkGeo.MapSuite.PortableCore.CreatedMemberNodeGeoObjectModelerEventArgs
<!– Class –> This class represents the parameters passed in through the CreatedMemberNode event.
Public MethodCreatedMemberNodeGeoObjectModelerEventArgs Creates an instance of MemberNodeCreatedGeoObjectModelerEventArgs.
Public MethodCreatedMemberNodeGeoObjectModelerEventArgs String, Object, Type, Object, GeoObjectNode Creates an instance of MemberNodeCreatedGeoObjectModelerEventArgs with name, value, type, owner and node.
Public MethodGetType Object
Public MethodToString Object
Public PropertyName String Gets or sets the name of the member.
Public PropertyNode GeoObjectNode Gets or sets the node of the member.
Public PropertyOwner Object Gets or sets the owner of the member.
Public PropertyType Type Gets or sets the type of the member.
Public PropertyValue Object Gets or sets the value of the member.
CreatedMemberNodeGeoObjectModelerEventArgs()
Name Type Description
Go Back
CreatedMemberNodeGeoObjectModelerEventArgs(String, Object, Type, Object, GeoObjectNode)
name String<!– System.String –> The name of the member.
value Object<!– System.Object –> The value of the member.
type Type<!– System.Type –> The type of the member.
owner Object<!– System.Object –> The owner of the member.
node GeoObjectNode<!– ThinkGeo.MapSuite.PortableCore.GeoObjectNode –> The node of the member.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Void<!– System.Void –>
Return Type
<!– ThinkGeo.MapSuite.PortableCore.CreatedMemberNodeGeoObjectModelerEventArgs –> Go Back
Node
Return Type
Owner
Return Type
Type
Return Type
Value
Return Type
thinkgeo.mapsuite.portablecore.createdmembernodegeoobjectmodelereventargs.1440040132.txt.gz · Last modified: 2015/09/21 08:05 (external edit)
