thinkgeo.mapsuite.portablecore.buildingindexshapefilefeaturesourceeventargs
ThinkGeo.MapSuite.Core.BuildingIndexShapeFileFeatureSourceEventArgs
This class represents the parameters passed in through the BuildingIndex event in ShapeFileFeatureSource class.
      • ThinkGeo.MapSuite.Core.BuildingIndexShapeFileFeatureSourceEventArgs
BuildingIndexShapeFileFeatureSourceEventArgs()
  • This is the default constructor of the event args.
  • If you use this constructor, you have to set the properties manually.
BuildingIndexShapeFileFeatureSourceEventArgs(Int32,Int32,Feature,DateTime,Boolean)
  • This is the constructor of the event args by passing the desired parameters.
  • recordCount
  • currentRecordIndex
  • currentFeature
  • startProcessTime
    • Type:DateTime
  • cancel
BuildingIndexShapeFileFeatureSourceEventArgs(Int32,Int32,Feature,DateTime,Boolean,String)
  • recordCount
  • currentFeature
  • startProcessTime
    • Type:DateTime
  • cancel
  • shapePathFileName
RecordCount
  • Gets the total record count to build rTree index.
CurrentRecordIndex
  • Gets the current record index for building rTree index.
CurrentFeature
  • Gets the current feature for building rTree index.
StartProcessTime
  • Gets the starting process time for building the index.
  • Type:DateTime
Cancel
  • Gets or sets to see if we need to cancel the building index of current record.
ShapePathFileName
thinkgeo.mapsuite.portablecore.buildingindexshapefilefeaturesourceeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
