<!– Class –> This is the event arguments class for the AdornmentLayersDrawn event. It is raised after all of the AdornmentLayers have been drawn.
This is the event arguments class for the AdornmentLayersDrawn event. It is raised after all of the AdornmentLayers have been drawn. This event allows you to manipulate the AdornmentLayers, or draw something with the canvas after all of the AdornmentLayers have been drawn.
*System.Object System.EventArgs *ThinkGeo.MapSuite.PortableCore.AdornmentLayersDrawnEventArgs
AdornmentLayersDrawnEventArgs | This is the default constructor for the class. | ||
AdornmentLayersDrawnEventArgs | IEnumerable<AdornmentLayer> | This is a constructor for the class. |
AdornmentLayers | IEnumerable<AdornmentLayer> | This property gets and sets the AdornmentLayers that have been drawn. |
| adornmentLayers | IEnumerable<AdornmentLayer><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.AdornmentLayer} –> | This parameter is the AdornmentLayers that have been drawn. |
<!– ThinkGeo.MapSuite.PortableCore.AdornmentLayersDrawnEventArgs –> Go Back
