thinkgeo.mapsuite.portablecore.adornmentlayersdrawneventargs
ThinkGeo.MapSuite.Core.AdornmentLayersDrawnEventArgs
This is the event arguments class for the AdornmentLayersDrawn event. It is raised after all of the AdornmentLayers have been drawn.
      • ThinkGeo.MapSuite.Core.AdornmentLayersDrawnEventArgs
AdornmentLayersDrawnEventArgs()
  • This is the default constructor for the class.
AdornmentLayersDrawnEventArgs(IEnumerable<AdornmentLayer>)
  • None
  • adornmentLayers
    • Type:IEnumerable<AdornmentLayer>
    • Description:This parameter is the AdornmentLayers that have been drawn.
AdornmentLayers
  • This property gets and sets the AdornmentLayers that have been drawn.
  • None
thinkgeo.mapsuite.portablecore.adornmentlayersdrawneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
