<!– Class –> This is the event arguments class for the AdornmentLayerDrawn event. It is raised after the AdornmentLayer is drawn.
This is the event arguments class for the AdornmentLayerDrawn event. It is raised after the AdornmentLayer is drawn. This event allows you to manipulate the AdornmentLayer, or draw something with the canvas after the AdornmentLayer has been drawn.
*System.Object System.EventArgs *ThinkGeo.MapSuite.PortableCore.AdornmentLayerDrawnEventArgs
AdornmentLayerDrawnEventArgs | This is the default constructor for the class. | ||
AdornmentLayerDrawnEventArgs | AdornmentLayer | This is a constructor for the class. |
AdornmentLayer | AdornmentLayer | This property gets and sets the AdornmentLayer that has been drawn. |
| adornmentLayer | AdornmentLayer<!– ThinkGeo.MapSuite.PortableCore.AdornmentLayer –> | This parameter is the AdornmentLayer that has been drawn. |
<!– ThinkGeo.MapSuite.PortableCore.AdornmentLayerDrawnEventArgs –> Go Back
