thinkgeo.mapsuite.portablecore.adornmentlayerdrawneventargs
ThinkGeo.MapSuite.Core.AdornmentLayerDrawnEventArgs
      • ThinkGeo.MapSuite.Core.AdornmentLayerDrawnEventArgs
AdornmentLayerDrawnEventArgs()
  • This is the default constructor for the class.
AdornmentLayerDrawnEventArgs(AdornmentLayer)
  • None
  • adornmentLayer
    • Description:This parameter is the AdornmentLayer that has been drawn.
AdornmentLayer
  • This property gets and sets the AdornmentLayer that has been drawn.
  • None
thinkgeo.mapsuite.portablecore.adornmentlayerdrawneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
