<!– Class –> A setting for YahooOverlay that contains APIs to set properties of YahooOverlaySetting using in MVC view.
*System.Object
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.YahooOverlaySetting * PublicKeyToken=null] Culture=neutral * Version=7.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.YahooOverlay PublicKeyToken=null]] * Culture=neutral Version=7.0.0.0 * MvcEdition [ThinkGeo.MapSuite.MvcEdition.YahooOverlaySetting * PublicKeyToken=null] Culture=neutral * Version=7.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.OverlaySetting`2[[ThinkGeo.MapSuite.MvcEdition.YahooOverlay **ThinkGeo.MapSuite.MvcEdition.YahooOverlaySetting
YahooOverlaySetting | YahooOverlay | Initializes a new instance of the YahooOverlaySetting class. |
AutoRefreshInterval | TimeSpan | OverlaySetting<YahooOverlay,YahooOverlaySetting> | |
Id | String | OverlaySetting<YahooOverlay,YahooOverlaySetting> | |
IsBaseOverlay | Boolean | OverlaySetting<YahooOverlay,YahooOverlaySetting> | |
IsVisible | Boolean | OverlaySetting<YahooOverlay,YahooOverlaySetting> | |
IsVisibleInOverlaySwitcher | Boolean | OverlaySetting<YahooOverlay,YahooOverlaySetting> | |
JavaScriptLibraryUri | Uri | Set javaScriptLibraryUri for Element property and retun the YahooOverlaySetting | |
Name | String | OverlaySetting<YahooOverlay,YahooOverlaySetting> | |
OnClientAutoRefreshTick | String | OverlaySetting<YahooOverlay,YahooOverlaySetting> | |
Opacity | Single | OverlaySetting<YahooOverlay,YahooOverlaySetting> | |
ToString | Object | ||
YahooMapType | YahooMapType | Set YahooMapType for Element property and retun the YahooOverlaySetting |
Element | YahooOverlay | MvcElementSettingBase<YahooOverlay,YahooOverlaySetting> |
| YahooOverlay | YahooOverlay<!– ThinkGeo.MapSuite.MvcEdition.YahooOverlay –> | the Yahoo Overlay which will be assigned to Element property |
| YahooOverlaySetting<!– ThinkGeo.MapSuite.MvcEdition.YahooOverlaySetting –> |
| timeSpan | TimeSpan<!– System.TimeSpan –> |
<!– ThinkGeo.MapSuite.MvcEdition.OverlaySetting{ThinkGeo.MapSuite.MvcEdition.YahooOverlay,ThinkGeo.MapSuite.MvcEdition.YahooOverlaySetting} –> Go Back
| id | String<!– System.String –> |
| isBaseOverlay | Boolean<!– System.Boolean –> |
| isVisible | Boolean<!– System.Boolean –> |
| isVisibleInOverlaySwitcher | Boolean<!– System.Boolean –> |
| YahooOverlaySetting<!– ThinkGeo.MapSuite.MvcEdition.YahooOverlaySetting –> | The setting of YahooOverlaySetting itself |
| javaScriptLibraryUri | Uri<!– System.Uri –> | A javaScriptLibraryUri for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.YahooOverlaySetting –> Go Back
| name | String<!– System.String –> |
| clientTickFunctionName | String<!– System.String –> |
| opacity | Single<!– System.Single –> |
| YahooMapType | YahooMapType<!– ThinkGeo.MapSuite.MvcEdition.YahooMapType –> | A YahooMapType for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.YahooOverlay,ThinkGeo.MapSuite.MvcEdition.YahooOverlaySetting} –> Go Back
