thinkgeo.mapsuite.mvcedition.worldmapkitwmsweboverlay
ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlay
<!– Class –> Represents an overlay object that gets map images from the WMS servers.
The <strong>WorldMapKitWmsWebOverlay</strong> gets images from four WMS servers that we specify by default. Usually, you add a WMS server URI to the <strong>ServerUris</strong> collection and the <strong>WorldMapKitWmsWebOverlay</strong> will make requests to that WMS servers to get its tile images.
The WorldMapKitWmsWebOverlay will randomly send requests to those WMS servers in a concurrent fashion. This means that the tile images can come from different WMS servers, thus greatly enhancing performance.
Public MethodWorldMapKitWmsWebOverlay Initialize an instance of the WmsOverlay class.
Public MethodWorldMapKitWmsWebOverlay String Initialize an instance of the WmsOverlay class with the overlay identifier specified.
Public MethodWorldMapKitWmsWebOverlay WorldMapKitLayerType
Public MethodWorldMapKitWmsWebOverlay String, WorldMapKitLayerType
Public MethodWorldMapKitWmsWebOverlay String, TileType Initialize an instance of the WmsOverlay class with the overlay identifier specified.
Public MethodWorldMapKitWmsWebOverlay String, TileType, WorldMapKitLayerType
Public MethodFromJson String Overlay(overriden)
Public MethodGetType Object
Public MethodToJson Overlay Returns a JSON string which contains the information for creating an overlay at the client side.
Public MethodToString Object
Protected MethodRegisterJavaScriptLibraryCore Page Overlay Registers a Javascript library URL string to the client HTML page.
Public PropertyAttribution String Overlay
Public PropertyAutoRefreshInterval TimeSpan Overlay Gets or sets the time interval in which the MarkerOverlay refreshes itself.
Public PropertyId String Overlay Gets the identifier for the overlay to be found.
Public PropertyIsBaseOverlay Boolean Overlay Gets or sets a value that indicates whether the overlay is a base overlay.
Public PropertyIsVisible Boolean Overlay Gets or sets a value that indicates whether the overlay is visible on the map.
Public PropertyIsVisibleInOverlaySwitcher Boolean Overlay Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
Public PropertyLayerType WorldMapKitLayerType
Public PropertyMapType WorldMapKitMapType
Public PropertyName String Overlay Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
Public PropertyOnClientAutoRefreshTick String Overlay(overriden) Don't support auto tick event by default.
Public PropertyOpacity Single Overlay Gets or sets the opacity level of the overlay.
Public PropertyProjection WorldMapKitProjection Gets or sets a WorldMapKitProjection represents which projection will be used.
Public PropertyTileType TileType Gets or sets whether or not the WmsOverlay uses tiling.
Public PropertyTransitionEffect TransitionEffect Gets or sets the transition effect to use when the map is zoomed.
Public PropertyTransitionEffectDelayInMilliseconds Int32
Public PropertyWrapDateline WrapDatelineMode Gets or sets a value that indicates whether the overlay wraps at the date line.
Protected PropertyOverlayType String Overlay(overriden) Gets a string that indicates the overlay type.
WorldMapKitWmsWebOverlay()
Overloads
Name Type Description
Go Back
WorldMapKitWmsWebOverlay(String)
Overloads
id String<!– System.String –> The identifier string used to find the overlay.
Go Back
WorldMapKitWmsWebOverlay(WorldMapKitLayerType)
layerType WorldMapKitLayerType<!– ThinkGeo.MapSuite.Core.WorldMapKitLayerType –>
Go Back
WorldMapKitWmsWebOverlay(String, WorldMapKitLayerType)
Go Back
WorldMapKitWmsWebOverlay(String, TileType)
Overloads
tileType TileType<!– ThinkGeo.MapSuite.MvcEdition.TileType –> Whether or not the overlay uses tiling.
Go Back
WorldMapKitWmsWebOverlay(String, TileType, WorldMapKitLayerType)
Go Back
Return Type Description
Boolean<!– System.Boolean –>
FromJson(String)
Void<!– System.Void –>
jsonString String<!– System.String –>
<!– ThinkGeo.MapSuite.MvcEdition.Overlay(overriden) –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
ToJson()
String<!– System.String –> A JSON string which is used to create an overlay at the client side.
<!– ThinkGeo.MapSuite.MvcEdition.Overlay –> Go Back
The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
page Page<!– System.Web.UI.Page –> The page object that is used for registering the javascript library.
Attribution
Return Type
AutoRefreshInterval
Return Type
TimeSpan<!– System.TimeSpan –>
Id
Return Type
IsBaseOverlay
Return Type
IsVisible
Return Type
Return Type
LayerType
Return Type
<!– ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlay –> Go Back
MapType
Return Type
WorldMapKitMapType<!– ThinkGeo.MapSuite.Core.WorldMapKitMapType –>
Return Type
Return Type
Opacity
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Return Type
Single<!– System.Single –>
Projection
Return Type
WorldMapKitProjection<!– ThinkGeo.MapSuite.Core.WorldMapKitProjection –>
TileType
Return Type
TransitionEffect
Return Type
TransitionEffect<!– ThinkGeo.MapSuite.MvcEdition.TransitionEffect –>
Return Type
WrapDateline
Return Type
WrapDatelineMode<!– ThinkGeo.MapSuite.MvcEdition.WrapDatelineMode –>
OverlayType
Return Type
thinkgeo.mapsuite.mvcedition.worldmapkitwmsweboverlay.1440040132.txt.gz · Last modified: 2015/09/21 03:36 (external edit)
