thinkgeo.mapsuite.portablecore.areastyleadvanced
ThinkGeo.MapSuite.Core.AreaStyleAdvanced
This class represents the advanced drawing options for area styles.
    • ThinkGeo.MapSuite.Core.AreaStyleAdvanced
AreaStyleAdvanced()
  • This is the default constructor for the class.
  • None
CloneDeep()
  • Create a copy of AreaStyleAdvanced class using the deep clone process.
  • The difference between deep clone and shallow clone is as follows: In shallow cloning, only the object is copied; the objects within it are not. By contrast, deep cloning copies the cloned object as well as all the objects within.
FillCustomBrush
  • This property allows you to get and set a custom fill brush.
  • This allows you to use custom brushes to achieve effects such as linear gradients and bitmap fills. If you use any brush besides the SolidBrush, you would set it in this property.
thinkgeo.mapsuite.portablecore.areastyleadvanced.txt · Last modified: 2017/03/16 21:59 (external edit)
