<!– Class –> This class defines the base abstract class for creating MVC control.
MvcControlBase | Initializes a new instance of the MvcControlBase class. | ||
MvcControlBase | String | Initializes a new instance of the MvcControlBase class. |
Fill | String | Fill an instance according to the input entity string | |
Fill | String, String | Fill an instance based on the input model name according to the input entity string | |
ToString | String | Convert current object based on mode name to an entity string. | |
ToString | Object(overriden) |
ClientScriptBlocks | Dictionary<String,String> | Gets the client script blocks which will be registered to the page. | |
ClientScriptFileNames | Dictionary<String,String> | Gets the client script files which will be registered to the page. | |
Height | Unit | Gets or sets the height of the control. | |
HtmlAttributes | Dictionary<String,String> | Gets the customized html attributes of the control. | |
Id | String | Gets the client id of the control, it will be calculated from Name property. | |
Name | String | Gets the unique identifier name of the control. | |
StyleSheetFileNames | Collection<String> | Gets the css files which will be wrote to the client html. | |
ViewContext | ViewContext | Gets the ViewContext of the page which includes the control. | |
Visible | Boolean | Gets or sets the visibility of the control. | |
Width | Unit | Gets or sets the width of the control. |
ClientScriptManager | MvcClientScriptManager | Gets the object which is used for managing, registering the client scripts. | |
ClientStyleSheetManager | MvcClientStyleSheetManager | Gets the object which is used for managing, registering the css files used by the control. |
| name | String<!– System.String –> | The unique identifier name of the control. |
| entityString | String<!– System.String –> | the inpu entity string. |
<!– ThinkGeo.MapSuite.MvcEdition.MvcControlBase –> Go Back
| modelName | String<!– System.String –> | the input model name |
| entityString | String<!– System.String –> | the input entity string |
| String<!– System.String –> | an entity string |
| modelName | String<!– System.String –> | model name |
| Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
| Unit<!– System.Web.UI.WebControls.Unit –> |
| ViewContext<!– System.Web.Mvc.ViewContext –> |
| MvcClientScriptManager<!– ThinkGeo.MapSuite.MvcEdition.MvcClientScriptManager –> |
| MvcClientStyleSheetManager<!– ThinkGeo.MapSuite.MvcEdition.MvcClientStyleSheetManager –> |
