<!– Class –> Determines whether the map can be operated by mouse.
The <strong>MouseMapTool</strong> control is enabled by default. You can prohibit the map from reacting to the mouse by setting the <strong>Enabled</strong> property to false.
![]() | Initialize an instance of the MouseMapTool class. |
![]() | Object | ||
![]() | Object |
![]() | Boolean | MapTool | Gets or sets a value that turns the feature on and off. |
![]() | Boolean | Set whether mouse wheel events are disabled or not. | |
![]() | TrackZoomMaskType | Set the zoom box key code of the key,which has to be pressed, while drawing the zoom box with the mouse on the screen. |
Name | Type | Description |
Return Type | Description |
Load this object from a json string.
Void<!– System.Void –> |
jsonString | String<!– System.String –> | a json string |
<!– ThinkGeo.MapSuite.MvcEdition.MapTool –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
Returns a JSON string that represents the map control object.
This method returns a JSON string that instructs the client Javascript to create a specific client object.
String<!– System.String –> | A JSON string that represents the map control. |
Return Type |
Return Type |
<!– ThinkGeo.MapSuite.MvcEdition.MouseMapTool –> Go Back
Return Type |
TrackZoomMaskType<!– ThinkGeo.MapSuite.MvcEdition.TrackZoomMaskType –> |
