thinkgeo.mapsuite.mvcedition.minimapmaptoolsetting
ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting
<!– Class –> A setting for MiniMapMapTool that contains APIs to set properties of MiniMapMapToolSetting using in MVC view.
*System.Object
  • PublicKeyToken=null]]
    • Culture=neutral
      • Version=9.0.0.0
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool PublicKeyToken=null]] * Culture=neutral Version=9.0.0.0 * MvcEdition [ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MapToolSetting`2[[ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool **ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting
Public MethodMiniMapMapToolSetting MiniMapMapTool Initializes a new instance of the MiniMapMapToolSetting class.
Public MethodEnabled Boolean MapToolSetting<MiniMapMapTool,MiniMapMapToolSetting>
Public MethodGetType Object
Public MethodMaximizeRatio Int32 Set maximize Ratio of map for Element property and retun the MiniMapMapToolSetting
Public MethodMinimizeRatio Int32 Set minimize Ratio of map for Element property and retun the MiniMapMapToolSetting
Public MethodToString Object
MiniMapMapToolSetting(MiniMapMapTool)
Name Type Description
mapTool MiniMapMapTool<!– ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool –>
Go Back
Enabled(Boolean)
Return Type Description
MiniMapMapToolSetting<!– ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting –>
isEnabled Boolean<!– System.Boolean –>
<!– ThinkGeo.MapSuite.MvcEdition.MapToolSetting{ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool,ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting} –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
MaximizeRatio(Int32)
MiniMapMapToolSetting<!– ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting –> The setting of MiniMapMapToolSetting itself
maximizeRatio Int32<!– System.Int32 –> A maximize Ratio of map for Element property
<!– ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting –> Go Back
MinimizeRatio(Int32)
minimizeRatio Int32<!– System.Int32 –> A minimize Ratio of map for Element property
String<!– System.String –>
Void<!– System.Void –>
Element
Return Type
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool,ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting} –> Go Back
thinkgeo.mapsuite.mvcedition.minimapmaptoolsetting.1440040131.txt.gz · Last modified: 2015/09/21 03:34 (external edit)
