<!– Class –> Represents the measure map tool which allows measurements for features.
MeasureMapTool | Initialize an instance of the MeasureMapTool class. |
Enabled | Boolean | MapTool | Gets or sets a value that turns the feature on and off. |
Geodesic | Boolean | Indicate whether to measure geodesic distance. | |
MeasureType | MeasureType | Represents the different types of the MeasureMapTool. | |
MeasureUnitType | MeasureUnitType | Represents the display system units for output measurements. |
The default MeasureType is Line, and the display system units is Metric by default, also it measures geodesic distance by default.
Load this object from a json string.
| jsonString | String<!– System.String –> | a json string |
<!– ThinkGeo.MapSuite.MvcEdition.MapTool –> Go Back
Returns a JSON string that represents the map control object.
This method returns a JSON string that instructs the client Javascript to create a specific client object.
| String<!– System.String –> | A JSON string that represents the map control. |
<!– ThinkGeo.MapSuite.MvcEdition.MeasureMapTool –> Go Back
| MeasureType<!– ThinkGeo.MapSuite.MvcEdition.MeasureType –> |
| MeasureUnitType<!– ThinkGeo.MapSuite.MvcEdition.MeasureUnitType –> |
