<!– Class –> A setting for LoadingImageMapTool that contains APIs to set properties of LoadingImageMapToolSetting using in MVC view.
*System.Object
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool PublicKeyToken=null]] * Culture=neutral Version=9.0.0.0 * MvcEdition [ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MapToolSetting`2[[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool **ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting
LoadingImageMapToolSetting | LoadingImageMapTool | Initializes a new instance of the LoadingImageMapToolSetting class. |
Enabled | Boolean | MapToolSetting<LoadingImageMapTool,LoadingImageMapToolSetting> | |
Height | Int32 | Set height for Element property and retun the LoadingImageMapToolSetting | |
ImageUri | Uri | Set imageUri for Element property and retun the LoadingImageMapToolSetting | |
ToString | Object | ||
Width | Int32 | Set width for Element property and retun the LoadingImageMapToolSetting |
Element | LoadingImageMapTool | MvcElementSettingBase<LoadingImageMapTool,LoadingImageMapToolSetting> |
| mapTool | LoadingImageMapTool<!– ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool –> | the map Tool which will be assigned to Element property |
| LoadingImageMapToolSetting<!– ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting –> |
| isEnabled | Boolean<!– System.Boolean –> |
<!– ThinkGeo.MapSuite.MvcEdition.MapToolSetting{ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool,ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting} –> Go Back
| LoadingImageMapToolSetting<!– ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting –> | The setting of LoadingImageMapToolSetting itself |
| height | Int32<!– System.Int32 –> | A height for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting –> Go Back
| imageUri | Uri<!– System.Uri –> | A imageUri for Element property |
| width | Int32<!– System.Int32 –> | A width for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool,ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting} –> Go Back
