<!– Class –> Represents a small image that displays at the center of the map when the map is loading.
This map control displays an image at the center of the map, indicating that the map is now busy getting images from the server. Usually the image is in GIF format.
*System.Object ThinkGeo.MapSuite.MvcEdition.MapTool *ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool
![]() | Initialize an instance of LoadingImageMapTool class. |
![]() | Object | ||
![]() | Object |
Name | Type | Description |
Return Type | Description |
Load this object from a json string.
Void<!– System.Void –> |
jsonString | String<!– System.String –> | a json string |
<!– ThinkGeo.MapSuite.MvcEdition.MapTool –> Go Back
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
Returns a JSON string that represents the map control object.
This method returns a JSON string that instructs the client Javascript to create a specific client object.
String<!– System.String –> | A JSON string that represents the map control. |
Gets or sets a value that turns the feature on and off.
Return Type |
Gets or sets the height of the loading image.
Return Type |
<!– ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool –> Go Back
Gets or sets the URI of the loading image.
Return Type |
Uri<!– System.Uri –> |
Gets or sets the width of the loading image.
Return Type |
