<!– Class –> A setting for KeyboardMapTool that contains APIs to set properties of KeyboardMapTool using in MVC view.
*System.Object
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.KeyboardMapToolSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.KeyboardMapTool PublicKeyToken=null]] * Culture=neutral Version=9.0.0.0 * MvcEdition [ThinkGeo.MapSuite.MvcEdition.KeyboardMapToolSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MapToolSetting`2[[ThinkGeo.MapSuite.MvcEdition.KeyboardMapTool **ThinkGeo.MapSuite.MvcEdition.KeyboardMapToolSetting
KeyboardMapToolSetting | KeyboardMapTool | Initializes a new instance of the KeyboardMapToolSetting class. |
Enabled | Boolean | MapToolSetting<KeyboardMapTool,KeyboardMapToolSetting> | |
PanPixels | Int32 | Set panPixels for Element property and retun the KeyboardMapToolSetting | |
Element | KeyboardMapTool | MvcElementSettingBase<KeyboardMapTool,KeyboardMapToolSetting> |
| mapTool | KeyboardMapTool<!– ThinkGeo.MapSuite.MvcEdition.KeyboardMapTool –> | the map Tool which will be assigned to Element property |
| KeyboardMapToolSetting<!– ThinkGeo.MapSuite.MvcEdition.KeyboardMapToolSetting –> |
| isEnabled | Boolean<!– System.Boolean –> |
<!– ThinkGeo.MapSuite.MvcEdition.MapToolSetting{ThinkGeo.MapSuite.MvcEdition.KeyboardMapTool,ThinkGeo.MapSuite.MvcEdition.KeyboardMapToolSetting} –> Go Back
| KeyboardMapToolSetting<!– ThinkGeo.MapSuite.MvcEdition.KeyboardMapToolSetting –> | The setting of KeyboardMapToolSetting itself |
| panPixels | Int32<!– System.Int32 –> | A panPixels for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.KeyboardMapToolSetting –> Go Back
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.KeyboardMapTool,ThinkGeo.MapSuite.MvcEdition.KeyboardMapToolSetting} –> Go Back
