<!– Class –> Determines whether the map can be operated by keyboard.
The <strong>KeyboardMapTool</strong> map control determines whether you can operate the map by keyboard. Set the <strong>Enabled</strong> property to true to enable the keyboard support of the map.
KeyboardMapTool | Initializes a new instance of the KeyboardMapTool class. |
Use this constructor to create and initialize a new instance of the <strong>KeyboardMapTool</strong> class.
Load this object from a json string.
| jsonString | String<!– System.String –> | a json string |
<!– ThinkGeo.MapSuite.MvcEdition.MapTool –> Go Back
Returns a JSON string that represents the map control object.
This method returns a JSON string that instructs the client Javascript to create a specific client object.
| String<!– System.String –> | A JSON string that represents the map control. |
Gets or sets a value that turns the feature on and off.
Gets or sets the number of pixels that are shifted by each keyboard-based panning operation.
The value of this property determines how many pixels to shift when using the arrow keys to pan.
<!– ThinkGeo.MapSuite.MvcEdition.KeyboardMapTool –> Go Back
