<!– Class –> A setting for CustomPopup that contains APIs to set properties of CustomPopupSetting using in MVC view.
*System.Object
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.CustomPopupSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.CustomPopup PublicKeyToken=null]] * Culture=neutral Version=9.0.0.0 * MvcEdition [ThinkGeo.MapSuite.MvcEdition.CustomPopupSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.PopupSetting`2[[ThinkGeo.MapSuite.MvcEdition.CustomPopup **ThinkGeo.MapSuite.MvcEdition.CustomPopupSetting
CustomPopupSetting | CustomPopup | Initializes a new instance of the CustomPopupSetting class. |
Element | CustomPopup | MvcElementSettingBase<CustomPopup,CustomPopupSetting> |
| popup | CustomPopup<!– ThinkGeo.MapSuite.MvcEdition.CustomPopup –> |
| CustomPopupSetting<!– ThinkGeo.MapSuite.MvcEdition.CustomPopupSetting –> |
| autoPan | Boolean<!– System.Boolean –> |
<!– ThinkGeo.MapSuite.MvcEdition.PopupSetting{ThinkGeo.MapSuite.MvcEdition.CustomPopup,ThinkGeo.MapSuite.MvcEdition.CustomPopupSetting} –> Go Back
| autoSize | Boolean<!– System.Boolean –> |
Set backgroundColor for Element property and retun the CustomPopupSetting
| CustomPopupSetting<!– ThinkGeo.MapSuite.MvcEdition.CustomPopupSetting –> | The setting of CustomPopupSetting itself |
| backgroundColor | GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> | A backgroundColor for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.CustomPopupSetting –> Go Back
Set backgroundImageVirtualPath for Element property and retun the CustomPopupSetting
| backgroundImageVirtualPath | String<!– System.String –> | A backgroundImageVirtualPath for Element property |
Set borderColor for Element property and retun the CustomPopupSetting
| borderColor | GeoColor<!– ThinkGeo.MapSuite.Core.GeoColor –> | A borderColor for Element property |
Set borderWidth for Element property and retun the CustomPopupSetting
| borderWidth | Int32<!– System.Int32 –> | A borderWidth for Element property |
Set contentHtml for Element property and retun the CustomPopupSetting
| contentHtml | String<!– System.String –> | A contentHtml for Element property |
| hasCloseButton | Boolean<!– System.Boolean –> |
| height | Int32<!– System.Int32 –> |
| isVisible | Boolean<!– System.Boolean –> |
| offsetXInPixels | Int32<!– System.Int32 –> |
| offsetYInPixels | Int32<!– System.Int32 –> |
| opacity | Single<!– System.Single –> |
| position | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> |
| width | Int32<!– System.Int32 –> |
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.CustomPopup,ThinkGeo.MapSuite.MvcEdition.CustomPopupSetting} –> Go Back
