thinkgeo.mapsuite.mvcedition.cloudpopup
ThinkGeo.MapSuite.MvcEdition.CloudPopup
Represents the popups that appear in a cloud (a.k.a. balloon) shape.
    • ThinkGeo.MapSuite.MvcEdition.Popup
      • ThinkGeo.MapSuite.MvcEdition.CloudPopup
CloudPopup()
Initialize an instance of the CloudPopup class.
CloudPopup(String)
Initialize an instance of the CloudPopup class with an Id string.
  • id
    • Description:The identifier by which you can find the popup.
CloudPopup(String,PointShape)
Initialize an instance of the CloudPopup class with an Id string and the position.
  • id
  • position
    • Description:A point shape in world coordinates that indicates the position of the popup.
CloudPopup(String,PointShape,String)
Initialize an instance of the CloudPopup class with an Id string, position and the content of the popup.
  • id
  • position
  • contentHtml
    • Description:An HTML string rendered as the popup content.
CloudPopup(String,PointShape,String,Int32,Int32)
Initialize an instance of the CloudPopup class with Id string, position, popup content and size.
  • id
  • position
  • contentHtml
  • width
    • Description:An int value that indicates the popup's width.
  • height
    • Description:An int value that indicates the popup's height.
CloudPopup(String,PointShape,String,Int32,Int32,Boolean)
Initialize an instance of the CloudPopup class with an Id string, position, popup content, popup size and a boolean value that determines whether to pan the map if necessary to show the full popup.
  • id
  • position
  • contentHtml
  • width
  • height
  • autoPan
    • Description:A boolean value indicating whether to pan the map if necessary to show the full popup.
CloudPopup(String,PointShape,String,Int32,Int32,Boolean,Boolean)
Initialize an instance of the CloudPopup class with an Id string, position, popup's content, popup size, a boolean value for whether to pan the map to show the popup, and a boolean value for whether to have a close button on the popup.
  • id
  • position
  • contentHtml
  • width
  • height
  • autoPan
  • hasCloseButton
    • Description:A boolean value indicating whether the popup should have a close button.
CloneShallow()
  • Type:Popup
ToJson()
FromJson(String)
  • jsonString
ContentHtml
Gets or sets the content HTML of the popup window.
Id
Position
Width
Height
IsVisible
Opacity
  • Type:Single
AutoSize
AutoPan
HasCloseButton
OffsetXInPixels
OffsetYInPixels
PopupType
Gets a string that represents the type of the Popup object.
thinkgeo.mapsuite.mvcedition.cloudpopup.1442806350.txt.gz · Last modified: 2015/09/21 03:32 by admin
