<!– Class –> Represents the popups that appear in a cloud (a.k.a. balloon) shape.
When you add a <strong>CloudPopup</strong> object to map, a cloud-shaped popup will be created at the client side.
You can put any HTML string in the <strong>ContentHtml</strong> property, which will be parsed and displayed in the popup.
![]() | Initialize an instance of the CloudPopup class. | ||
![]() | String | Initialize an instance of the CloudPopup class with an Id string. | |
![]() | String, PointShape | Initialize an instance of the CloudPopup class with an Id string and the position. | |
![]() | String, PointShape, String | Initialize an instance of the CloudPopup class with an Id string, position and the content of the popup. | |
![]() | String, PointShape, String, Int32, Int32 | Initialize an instance of the CloudPopup class with Id string, position, popup content and size. | |
![]() | String, PointShape, String, Int32, Int32, Boolean | Initialize an instance of the CloudPopup class with an Id string, position, popup content, popup size and a boolean value that determines whether to pan the map if necessary to show the full popup. | |
![]() | String, PointShape, String, Int32, Int32, Boolean, Boolean | Initialize an instance of the CloudPopup class with an Id string, position, popup's content, popup size, a boolean value for whether to pan the map to show the popup, and a boolean value for whether to have a close button on the popup. |
![]() | Popup | Creates a shallow copy of the current popup object. | |
![]() | Object | Object | |
![]() | String | Popup | |
![]() | Object | ||
![]() | Object | ||
![]() | Popup | Returns a JSON string which contains the popup's information and is used to create the popup at the client side. | |
![]() | Object |
![]() | Object | ||
![]() | Object |
![]() | Boolean | Popup | Gets or sets a value that indicates whether to pan the map to display the entire popup if the popup is not fully displayed. |
![]() | Boolean | Popup | Gets or sets a value that indicates whether the popup is automatically resized to fit its contents. |
![]() | String | Gets or sets the content HTML of the popup window. | |
![]() | Boolean | Popup | Gets or sets a value that indicates whether the popup window has a close button in the upper right corner. |
![]() | Int32 | Popup | Gets or sets the height of the popup. |
![]() | String | Popup | Gets the identifier by which you can find the popup. |
![]() | Boolean | Popup | Gets or sets a value that indicates whether the popup is visible on the map. |
![]() | Int32 | Popup | Gets or sets the popup's pixel offset in X direction. |
![]() | Int32 | Popup | Gets or sets the popup's pixel offset in Y direction. |
![]() | Single | Popup | Gets or sets the opacity level of the popup. |
![]() | PointShape | Popup | Gets or sets a point shape in world coordinates that represents the position of the popup. |
![]() | Int32 | Popup | Gets or sets the width of the popup. |
Name | Type | Description |
id | String<!– System.String –> | The identifier by which you can find the popup. |
position | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | A point shape in world coordinates that indicates the position of the popup. |
contentHtml | String<!– System.String –> | An HTML string rendered as the popup content. |
width | Int32<!– System.Int32 –> | An int value that indicates the popup's width. |
height | Int32<!– System.Int32 –> | An int value that indicates the popup's height. |
autoPan | Boolean<!– System.Boolean –> | A boolean value indicating whether to pan the map if necessary to show the full popup. |
hasCloseButton | Boolean<!– System.Boolean –> | A boolean value indicating whether the popup should have a close button. |
Return Type | Description |
Popup<!– ThinkGeo.MapSuite.MvcEdition.Popup –> |
<!– ThinkGeo.MapSuite.MvcEdition.Popup –> Go Back
Void<!– System.Void –> |
jsonString | String<!– System.String –> |
Type<!– System.Type –> |
String<!– System.String –> | A string that is used to create the popup at the client side. |
Return Type |
Return Type |
Return Type |
<!– ThinkGeo.MapSuite.MvcEdition.CloudPopup –> Go Back
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
The <strong>Opacity</strong> property enables you to specify a level of transparency for the popup. When this property is set to a value less than 100 percent (1.00), the entire popup (including its content) is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the popup completely invisible.
Return Type |
Single<!– System.Single –> |
Return Type |
Return Type |
Gets a string that represents the type of the Popup object.
Return Type |
<!– ThinkGeo.MapSuite.MvcEdition.Popup(overriden) –> Go Back
