<!– Class –> A setting for ContextMenu that contains APIs to set properties of ContextMenu using in MVC view.
*System.Object
* MvcEdition [ThinkGeo.MapSuite.MvcEdition.AnimationPanMapToolSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.AnimationPanMapTool PublicKeyToken=null]] * Culture=neutral Version=9.0.0.0 * MvcEdition [ThinkGeo.MapSuite.MvcEdition.AnimationPanMapToolSetting * PublicKeyToken=null] Culture=neutral * Version=9.0.0.0 MvcEdition *ThinkGeo.MapSuite.MvcEdition.MapToolSetting`2[[ThinkGeo.MapSuite.MvcEdition.AnimationPanMapTool **ThinkGeo.MapSuite.MvcEdition.AnimationPanMapToolSetting
AnimationPanMapToolSetting | AnimationPanMapTool | Initializes a new instance of the AnimationPanMapToolSetting class. |
Delay | Int32 | Set delay for Element property and retun the AnimationPanMapToolSetting | |
Enabled | Boolean | MapToolSetting<AnimationPanMapTool,AnimationPanMapToolSetting> | |
OnClientClick | String | Set onClientClick javascript function name for Element property and retun the AnimationPanMapToolSetting | |
Element | AnimationPanMapTool | MvcElementSettingBase<AnimationPanMapTool,AnimationPanMapToolSetting> |
| mapTool | AnimationPanMapTool<!– ThinkGeo.MapSuite.MvcEdition.AnimationPanMapTool –> | the map Tool which will be assigned to Element property |
| AnimationPanMapToolSetting<!– ThinkGeo.MapSuite.MvcEdition.AnimationPanMapToolSetting –> | The setting of AnimationPanMapToolSetting itself |
| delay | Int32<!– System.Int32 –> | A delay for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.AnimationPanMapToolSetting –> Go Back
| isEnabled | Boolean<!– System.Boolean –> |
<!– ThinkGeo.MapSuite.MvcEdition.MapToolSetting{ThinkGeo.MapSuite.MvcEdition.AnimationPanMapTool,ThinkGeo.MapSuite.MvcEdition.AnimationPanMapToolSetting} –> Go Back
| onClientClick | String<!– System.String –> | A onClientClick javascript function name for Element property |
<!– ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.AnimationPanMapTool,ThinkGeo.MapSuite.MvcEdition.AnimationPanMapToolSetting} –> Go Back
