<!– Class –> This class is the derived class of the MatchingPlugin class for matching street addresses.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin</a>
*System.Object ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin *ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin
![]() | This is the constructor of this class. | ||
![]() | String | This is the constructor of this class. | |
![]() | String, MatchMode | This is the constructor of this class. |
![]() | MatchingPlugin | This method closes the MatchingPlugin. This method is the concrete wrapper for CloseCore. | |
![]() | Releases all resources used by the StreetDbfMatchingPlugin. | ||
![]() | Object | Object | |
![]() | Object | ||
![]() | Object | ||
![]() | String | MatchingPlugin | This method matches the source text and returns a collection of GeocoderMatch. This method is the concrete wrapper for MatchCore. It firstly formalizes the input sourceText, gets the formalized results and matches them using MatchCore one by one, then returns all of the results within a collection. |
![]() | MatchingPlugin | This method opens the MatchingPlugin for use. This method is the concrete wrapper for OpenCore. | |
![]() | Object |
![]() | MatchingPlugin(overriden) | This method closes the StreetMatchingPlugin. | |
![]() | Object(overriden) | This method is automatically called after an object becomes inaccessible, unless the object has been exempted from finalization by a call to SuppressFinalize. | |
![]() | String | MatchingPlugin | This method formalizes the source text. This method is the concrete wrapper of FormalizeCore. |
![]() | String | MatchingPlugin(overriden) | This method formalizes the source text to get possible street addresses. |
![]() | String | MatchingPlugin(overriden) | This method matches source text in the corresponding street index files. |
![]() | Object | ||
![]() | MatchingPlugin(overriden) | This method opens the StreetMatchingPlugin. |
![]() | String | This property is the path to the Geocoder data folder. | |
![]() | MatchMode | This property is the match mode of the street matching plugin. | |
![]() | Int32 | MatchingPlugin | This property is the ranking multipier for GeocoderMatch. |
![]() | StreetNumberMatchingMode | This property is the street number match mode of the street matching plugin. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#StreetMatchingPlugin.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#StreetMatchingPlugin.28.29</a>
Name | Type | Description |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#StreetMatchingPlugin.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#StreetMatchingPlugin.28String.29</a>
dataPath | String<!– System.String –> | The path of the Geocoder data folder. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#StreetMatchingPlugin.28String.2C_MatchMode.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#StreetMatchingPlugin.28String.2C_MatchMode.29</a>
dataPath | String<!– System.String –> | The path to the Geocoder data folder. |
matchMode | MatchMode<!– ThinkGeo.MapSuite.MapSuiteGeocoder.MatchMode –> | This parameter is the match mode of the street matching plugin. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Close.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Close.28.29</a>
Return Type | Description |
Void<!– System.Void –> |
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Dispose.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Dispose.28.29</a>
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#GetHashCode.28.29</a>
Int32<!– System.Int32 –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#GetType.28.29</a>
Type<!– System.Type –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Match.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Match.28String.29</a>
Collection<GeocoderMatch><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch} –> | A collection of GeocoderMatch. |
sourceText | String<!– System.String –> | The source text to match. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Open.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Open.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#CloseCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#CloseCore.28.29</a>
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin(overriden) –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Formalize.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Formalize.28String.29</a>
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | The collection of formalized strings. |
sourceText | String<!– System.String –> | The source text to formalize. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#FormalizeCore.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#FormalizeCore.28String.29</a>
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | The collection containing possible street addresses. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#MatchCore.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#MatchCore.28String.29</a>
Collection<GeocoderMatch><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch} –> | The collection of GeocoderMatch objects. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#OpenCore.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#OpenCore.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#DataPath” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#DataPath</a>
Return Type |
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#RankingMultiplier” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#RankingMultiplier</a>
Return Type |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#StreetNumberMatchingMode” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#StreetNumberMatchingMode</a>
Return Type |
StreetNumberMatchingMode<!– ThinkGeo.MapSuite.MapSuiteGeocoder.StreetNumberMatchingMode –> |
