thinkgeo.mapsuite.mapsuitegeocoder.streetmatchingplugin
ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin
This class is the derived class of the MatchingPlugin class for matching street addresses.
    • ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin
      • ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin
StreetMatchingPlugin()
  • This is the constructor of this class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#StreetMatchingPlugin.28.29
StreetMatchingPlugin(String)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#StreetMatchingPlugin.28String.29
  • dataPath
    • Description:The path of the Geocoder data folder.
StreetMatchingPlugin(String,MatchMode)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#StreetMatchingPlugin.28String.2C_MatchMode.29
  • dataPath
    • Description:The path to the Geocoder data folder.
  • matchMode
    • Type:MatchMode
    • Description:This parameter is the match mode of the street matching plugin.
Dispose()
  • Releases all resources used by the StreetDbfMatchingPlugin.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Dispose.28.29
Match(String)
  • This method matches the source text and returns a collection of GeocoderMatch. This method is the concrete wrapper for MatchCore. It firstly formalizes the input sourceText, gets the formalized results and matches them using MatchCore one by one, then returns all of the results within a collection.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Match.28String.29
  • Type:Collection<GeocoderMatch>
  • Description:A collection of GeocoderMatch.
  • sourceText
    • Description:The source text to match.
Open()
  • This method opens the MatchingPlugin for use. This method is the concrete wrapper for OpenCore.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Open.28.29
Close()
  • This method closes the MatchingPlugin. This method is the concrete wrapper for CloseCore.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Close.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#GetType.28.29
OpenCore()
  • This method opens the StreetMatchingPlugin.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#OpenCore.28.29
CloseCore()
  • This method closes the StreetMatchingPlugin.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#CloseCore.28.29
MatchCore(String)
  • This method matches source text in the corresponding street index files.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#MatchCore.28String.29
  • Description:The collection of GeocoderMatch objects.
  • sourceText
cBQ=(String)
  • sourceText
cRQ=(String)
  • sourceText
FormalizeCore(String)
  • This method formalizes the source text to get possible street addresses.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#FormalizeCore.28String.29
  • Type:Collection<String>
  • Description:The collection containing possible street addresses.
  • sourceText
    • Description:The source text to formalize.
  • This method is automatically called after an object becomes inaccessible, unless the object has been exempted from finalization by a call to SuppressFinalize.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Finalize.28.29
Formalize(String)
  • This method formalizes the source text. This method is the concrete wrapper of FormalizeCore.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#Formalize.28String.29
  • Description:The collection of formalized strings.
  • sourceText
oxM=(GeocoderMatch)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#MemberwiseClone.28.29
MatchMode
This property is the match mode of the street matching plugin.
StreetNumberMatchingMode
This property is the street number match mode of the street matching plugin.
DataPath
This property is the path to the Geocoder data folder.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.StreetMatchingPlugin#DataPath
RankingMultiplier
This property is the ranking multipier for GeocoderMatch.
bxQ=
thinkgeo.mapsuite.mapsuitegeocoder.streetmatchingplugin.txt · Last modified: 2017/03/16 21:59 (external edit)
