thinkgeo.mapsuite.mapsuitegeocoder.soundex
ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex
This class is the abstract class for Soundex algorithm.
Soundex()
  • This is the constructor of this class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex#Soundex.28.29
GenerateSoundex(String)
  • This is the abstract method for generating Soundex code.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex#GenerateSoundex.28String.29
  • Description:The Soundex code for the given source string.
  • sourceText
    • Description:The source string to generate Soundex code.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex#GetType.28.29
EncodeChar(Char)
  • This is the virtual method to encode char.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex#EncodeChar.28Char.29
  • Description:Encoded char.
  • value
    • Type:Char
    • Description:Source char.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex#MemberwiseClone.28.29
thinkgeo.mapsuite.mapsuitegeocoder.soundex.txt · Last modified: 2017/03/16 21:59 (external edit)
