<!– Class –> This is the derived class from the Soundex class which implements a simplfied soundex algorithm.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex</a>
*System.Object ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex *ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex
SimplifiedSoundex | This is the constructor of this class. |
GenerateSoundex | String | Soundex(overriden) | This is the override method to generate soundex code. |
EncodeChar | Char | Soundex | This is the virtual method to encode char. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#SimplifiedSoundex.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#SimplifiedSoundex.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#GenerateSoundex.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#GenerateSoundex.28String.29</a>
| String<!– System.String –> | The soundex code generated from the source text. |
| sourceText | String<!– System.String –> | The source text to generate soundex. |
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex(overriden) –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#EncodeChar.28Char.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#EncodeChar.28Char.29</a>
| String<!– System.String –> | Encoded char. |
| value | Char<!– System.Char –> | Source char. |
<!– ThinkGeo.MapSuite.MapSuiteGeocoder.Soundex –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SimplifiedSoundex#MemberwiseClone.28.29</a>
