thinkgeo.mapsuite.mapsuitegeocoder.postcodedbfmatchingplugin
ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin
This is the derived class of the class MatchingPlugIn for matching PostCode.
    • ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin
      • ThinkGeo.MapSuite.MapSuiteGeocoder.PostcodeDbfMatchingPlugin
PostcodeDbfMatchingPlugin()
This is the constructor of this class.
PostcodeDbfMatchingPlugin(String)
  • dataPath
    • Description:The path to the Geocoder data folder.
Dispose()
Releases all resources used by the PostCodeDbfMatchingPlugin.
Match(String)
  • sourceText
Open()
Close()
OpenCore()
This method opens the PostCodeDbfMatchingPlugin.
CloseCore()
This method closes the PostCodeDbfMatchingPlugin.
MatchCore(String)
This method matches the source text in PostCode DBF file.
  • Type:Collection<GeocoderMatch>
  • Description:The collection of MatchItem objects.
  • sourceText
    • Description:This parameter is the source text to match.
This method is automatically called after an object becomes inaccessible, unless the object has been exempted from finalization by a call to SuppressFinalize.
Formalize(String)
  • Type:Collection<String>
  • sourceText
FormalizeCore(String)
  • sourceText
oxM=(GeocoderMatch)
DataPath
This property is the path to the Geocoder data folder.
RankingMultiplier
thinkgeo.mapsuite.mapsuitegeocoder.postcodedbfmatchingplugin.1442819033.txt.gz · Last modified: 2015/09/21 07:03 by admin
